Suunto 9 User Guide - 2.1
  • Time and date
Time and date
You set time and date during the initial startup of your watch. After this, your watch uses GPS time to correct any offset.
You can manually adjust time and date from the settings under GENERAL » Time/date where you can also change time and date formats.
In addition to the main time, you can use dual time to follow the time at a different location, for example, when you are traveling. Under General » Time/date, tap Dual time to set the time zone by selecting a location.
Once you have paired with Suunto app, your watch gets updated time, date, time zone and daylight-saving time from mobile devices.
Under General » Time/date, tap Auto time update to toggle the feature on and off.
Alarm clock
Your watch has an alarm clock that can sound once or repeat on specific days. Activate the alarm from the settings under Alarm » Alarm clock.
Besides standard fixed alarms, you will also find an adaptive alarm type based on data for sunrise and sunset. See Sunrise and sunset alarms.
To set a fixed alarm time:
  1. From the watch face, press the middle button to open the shortcuts menu and scroll to Alarms.
  2. First select how often you want the alarm to sound. The options are:
    Once: alarm sounds once in the next 24 hours at the set time Weekdays: alarm sounds at the same time Monday thru Friday Daily: alarm sounds at the same time every day of the week
    alarm settings step1
  3. Set the hour and minutes and then exit the settings.
    alarm settings step2
When the alarm sounds, you can dismiss it to end the alarm, or you can select the snooze option. The snooze time is 10 minutes and can be repeated up to 10 times.
Alarm dismiss snooze
If you let the alarm continue to sound, it will automatically snooze after 30 seconds.
