Suunto Nautic User Guide
- Wireless tank pressure support
Suunto Nautic can be used together with Suunto Tank POD for wireless transmission of tank pressure and gas consumption to the dive computer. Suunto Nautic is only compatible with Suunto Tank POD transmitters. Suunto Tank POD transmits data using 123 kHz band. The communication from the Tank POD to the dive computer is one-way, meaning the dive computer does not send anything to the Tank POD.
Enabled features when Suunto Nautic is paired to Suunto Tank POD:
Tank pressure from up to 5 gas cylinders
Actual gas consumption for the active gas (L/min or cu ft/min)
Remaining gas time for the active gas
Configurable tank pressure alarms
Tank switch alarm when diving sidemount
Logging of start, end and the used pressure
Logging of average gas consumption for every gas with Tank POD
Units in bar or PSI
