Suunto Aqua User Guide
Buttons
Suunto Aqua has three buttons you can use to switch song, adjust volume and answer or end phone calls.
buttons aqua
  1. multifunction button
  2. ○ ▷ button
  3. ◁ button
The default button functions are as follows:
Switching on/off the device
  1. keep the ○ ▷ button pressed for 3 seconds to switch the device on or off
Listening to audio
  • press the multifunction button once to start or stop playing the audio
  • press the multifunction button twice to skip to the next track
  • press the multifunction button three times to return to the previous track
  • press the ○ ▷ button to increase volume
  • press the ◁ button to decrease volume
  • keep the multifunction button and the ○ ▷ button pressed simultaneously for 3 seconds to switch sound mode
Making a phone call
  • press the multifunction button once to answer or end a call
  • long press the multifunction button to reject a call
Adjusting settings when the device is on
  • keep the multifunction button and the ◁ button pressed simultaneously for 3 seconds to enable Head movement control
  • keep the ◁ and ○ ▷ buttons pressed simultaneously for 3 seconds to activate exercise tracking (the default sport mode is pool swimming)
  • in pairing mode, keep the multifunction button and the ○ ▷ button pressed simultaneously for 3 seconds to enable dual device connection
  • press the ◁ button for 3 seconds to switch between Bluetooth mode and offline music mode
  • press the multifunction button for 3 seconds to activate the voice assistant on your phone
During charging
  • press the multifunctional button for 5 seconds to restore factory settings
You can customize button functions in the Suunto app. See Button customization.
