Suunto Wing User Guide
Getting started
Buttons
Suunto Wing has three buttons you can use to switch song, adjust volume and answer or end phone calls.
- multifunction button
- and power button
- button
Switching on/off the device
- keep the button pressed for 3 seconds to switch the device on or off
Listening to audio
- press the multifunction button once to start or stop playing the audio
- press the multifunction button twice to skip to the next track
- press the multifunction button three times to return to the previous track
- press the button to increase volume
- press the button to decrease volume
- keep the multifunction button and the button pressed simultaneously for 3 seconds to switch sound mode
Making a phone call
- press the multifunction button once to answer or end a call
Adjusting settings when the device is on
- keep the button pressed for 3 seconds to switch the LED lights on
- keep the button pressed again for 3 seconds to switch between different light modes
- keep the multifunction button and the button pressed simultaneously for 3 seconds to enable Head Movement Control
- keep the and buttons pressed simultaneously for 3 seconds to enter pairing mode
- in pairing mode, keep the multifunction button and the button pressed simultaneously for 3 seconds to enable dual device connection
