NEW! WE NOW SHIP TO MALAYSIA| FREE SHIPPING OVER RM1000 | EASY RETURNS | SIGN UP FOR NEWSLETTER
Suunto Spartan Sport Wrist HR Baro User Guide - 1.12
  • Sleep tracking
Sleep tracking
A good night's sleep is important for a healthy mind and body. You can use your watch to track your sleep and follow how much sleep you are getting on average.
When you wear your watch to bed, Suunto Spartan Sport Wrist HR Baro tracks your sleep based on accelerometer data. You can leave the watch next to your bed when going to sleep, but we recommend leaving it on so that you can get more accurate sleep feedback.
To track sleep:
  1. Go to your watch settings, scroll down to Sleep and press the middle button.
  2. Toggle on Sleep tracking.
    sleeptracking setting UltraSport
  3. Set the times for going to bed and waking up according to your normal sleep schedule.
The last step defines your bedtime. Your watch uses that period to determine when you are sleeping (during your bedtime) and reporting all sleep as one session. If you get up for a drink of water during the night, for example, your watch still counts any sleep after that as the same session.
If you go to bed before your bedtime and also wake up after your bedtime, your watch does not count that as a sleep session. You should set your bedtime according to the earliest you may go to bed and the latest you may wake up.
Once you have enabled sleep tracking, you can also set your sleep target. A typical adult needs between 7 and 9 hours of sleep per day, though your ideal amount of sleep may vary from the norms.
Sleep trends
When you wake up, you are greeted with a summary of your sleep. The summary includes, for example, the total duration of your sleep, as well as the estimated time you were awake (moving around) and the time you were in deep sleep (no movement).
In addition to the sleep summary, you can follow your overall sleep trend with the sleep insight. From the watch face, press the lower right button until you see the Sleep display. The first view shows your last sleep compared to your sleep target.
sleepinsight UltraSport
While in the sleep display, you can swipe right to see your average sleep over the last seven days.
From the Sleep display, you can keep the middle button pressed to access sleep tracking settings and the latest sleep summary.
All sleep measurements are based on movement only, so they are estimates that may not reflect your actual sleep habits.
Measuring heart rate while sleeping
If you wear your watch during the night, you can get additional feedback on your heart rate while sleeping. To keep the optical heart rate on during the night, ensure that Daily HR is enabled (see Daily HR) and Do Not Disturb mode is activated (see Do Not Disturb mode).
Automatic Do Not Disturb mode
You can use the auto Do Not Disturb setting to automatically enable Do Not Disturb mode while you sleep.
