The Suunto DM5 software program allows you to track and analyze all of your dive logs and plan your future dives. With DM5 you can customize your Suunto D5 and update the device firmware. Download Suunto DM5 from www.suunto.com/dm5.
Mono framework is required when using DM5 on a Mac.
To be able to synchronize logs and settings, you need to first install Suunto DM5 (see Suunto DM5).
To download logs from your Suunto D5 and sync settings:
New dive logs appear in the DM5 DIVES list on the left sorted by date and time.
Suunto DM5 is required to install new firmware for your Suunto D5. If a new firmware version is available, you are notified when connection is established between your Suunto D5 and DM5.
Before updating the firmware, make sure the USB is securely connected. The cable must not be unplugged until update process is completed.
Watch the video on YouTube.
To update firmware:
