NEW! WE NOW SHIP TO SINGAPORE | FREE SHIPPING OVER $325 | EASY RETURNS | SIGN UP FOR NEWSLETTER
Suunto Spartan Sport Wrist HR Baro User Guide - 1.12
  • Points of interest
Points of interest
A point of interest, or POI, is a special location, such as camping spot or vista along a trail, you can save and navigate to later. You can create POIs in Suunto Movescount or in your watch by saving your current location.
Each POI is defined by:
  • POI name
  • POI type
  • Date and time created
  • Latitude
  • Longitude
  • Elevation
You can store up to 250 POIs in your watch.
Adding and deleting POIs
You can add a POI to your watch either with Suunto Movescount or by saving your current location in the watch.
To add a POI with Suunto Movescount:
  1. Go to your watch settings on the Suunto Movescount website.
  2. Expand the Navigation section and then POIs (Points of Interest).
  3. Click Create new point of interest and fill in your POI details. Use the map to enter latitude and longitude.
  4. Save the POI and then add it to your watch by selecting Use in watch.
  5. Sync your watch with Movescount using SuuntoLink (USB cable) or Suunto Movescount App (Bluetooth).
If you are outside with your watch and come across a spot you want to save as a POI, you can add the location directly in your watch. The POI is added to your list of POIs in the watch and will be added to your POI list in Movescount the next time you sync.
To add a POI with your watch:
  1. Swipe down or press the upper button to open the launcher.
  2. Scroll to Navigation and tap on the icon or press the middle button.
  3. Swipe up or press the lower button to scroll down to Your location and press the middle button.
  4. Wait for the watch to activate GPS and find your location.
  5. When the watch displays your latitude and longitude, press the upper button to save your location as a POI and select the POI type.
  6. By default the POI name is the same as the POI type (with a running number after it). You can edit the name later in Movescount.
Deleting POIs
You can remove a POI from you watch either by deactivating the Use in watch setting for the POI in Movescount or by deleting the POI from the POI list in the watch.
To delete a POI in your watch:
  3. Swipe up or press the lower button to scroll down to POIs and press the middle button.
  4. Scroll to the POI you want to remove from the watch and press the middle button.
  5. Scroll to the end of the details and select Delete.
When you delete a POI from your watch, the POI is not permanently deleted. The next time you sync your watch with Movescount, the POI you deleted is deactivated.
To permanently delete a POI, you need to delete the POI in Movescount.
To permanently delete a POI:
  1. Go to your watch settings in Movescount.
  3. Scroll to the POI you want to delete and click on the trash bin icon.
  4. Sync your watch with Movescount using SuuntoLink (USB cable) or Suunto Movescount App (Bluetooth) to also remove the POI from your watch POI list.
Navigating to a POI
You can navigate to any POI that is in your watch POI list.
When navigating to a POI, your watch uses full power GPS.
To navigate to a POI:
  3. Scroll to POIs and press the middle button to open your list of POIs.
  4. Scroll to the POI you want to navigate to and press the middle button.
  5. Press the upper button to start navigating.
  6. Press the upper button again at any time to stop navigating.
The POI navigation has two views:
  • POI view with direction indicator and distance to the POI
POI detail view
  • map view showing your current location relative to the POI and your breadcrumb trail (the track you have traveled)
POI map view
Swipe left or right, or press the middle button, to switch between views.
While in the POI view, tap on the screen to see additional information in the lower row such as altitude difference between current position and POI and estimated time of arrival (ETA) or en route (ETE).
In the map view, other POIs nearby are shown in gray. Tap on the screen to switch between the overview map and a more detailed view. In the detailed view, you adjust the zoom level by pressing the middle button and then zooming in and out with the upper and lower buttons.
While navigating, you can swipe up from the bottom of the screen or press the lower button to open a list of shortcuts. The shortcuts give you quick access to POI details and actions such as saving your current location or selecting another POI to navigate to, as well as ending navigation.
POI types
The following POI types are available in Suunto Spartan Sport Wrist HR Baro:
poi basicgeneric point of interest
poi beddingBedding (animal, for hunting)
poi beginBegin (start of a route or trail)
poi biggameBig game (animal, for hunting)
poi birdBird (animal, for hunting)
poi homeBuilding, home
poi cafeCafe, food, restaurant
poi campCamp, camping
poi carCar, parking
poi caveCave
poi hillCliff, hill, mountain, valley
poi lakeCoast, lake, river, water
poi crossroadCrossroad
poi emergEmergency
poi endEnd (end of a route or trail)
poi fishFish, fishing spot
poi forestForest
poi geoGeogache
poi hotelHostel, hotel, lodging
poi infoInfo
poi meadowMeadow
poi peakPeak
poi printsPrints (animal tracks, for hunting)
poi roadRoad
poi rockRock
poi rubRub (animal marking, for hunting)
poi scrapeScrape (animal marking, for hunting)
poi shotShot (for hunting)
poi sightSight
poi smallgameSmall game (animal, for hunting)
poi standStand (for hunting)
poi trailTrail
poi camTrail cam (for hunting)
poi waterfallWaterfall
