Suunto 9 User Guide - 2.1
SuuntoPlus™: Weather - Insights
When hiking or trekking, it is always good to keep track on surrounding environment and weather status.
Weather insights provides the weather conditions in the context of your current hike. There is combination of functionalities that are beneficial to keep you alert on the changing conditions. You can get storm alarms, measure the water temperature, notice if your hike is going past the sunset and you can follow the barometric trend continuously.
To use Weather with Suunto 9:
  1. Before you start an exercise recording, swipe up or press the lower button to open the sport mode options.
  2. Scroll to and tap SuuntoPlus™ features or press the middle button.
  3. Scroll to and tap Weather or press the middle button.
  4. Scroll up to the start view and start your exercise as normal.
  5. During exercise, swipe left or press the middle button until you reach the Weather display to view Weather insights.
The Weather insights shows the following:
Sunrise / Sunset
The upcoming sunrise or sunset, depending on which is next.
Temperature
If you place the watch into the water (below 10 cm/ 4 inches) you can measure the water temperature. After you take the watch out of the water the temperature is shown for next 30 seconds. This is indicated with a separate temperature icon.
Measuring the water temperature will affect the ascent/descent values as these are pressure based.
Estimated time of arrival (ETA)
If the estimated time of arrival goes past the sunset, it will be shown in red.
Barometric trend and storm alarm
The barometric trend is shown on the bottom of the screen, with current barometric value. The Suunto storm alarm will be given automatically and shown in this view. A storm symbol is shown if the pressure drops 4 hPa (0.12 inHg) or more during a 3-hour period.
Oxygen level
If you are above 2000 m (6 561 ft) you will get a reading on the oxygen % compared to sea level.
