All Suunto watches and dive computers have a serial number. The serial number is a combination of 6, 8, 10 or 12 numbers without spaces or dashes.
Examples:
- 123456
- 12345678
- 1234567891
- 12345678910
Depending on your product and its generation, there are several locations where you can find the serial number of your product:
1) On the back of your device
In most cases, you will find the serial number printed externally at the back of the device module. Possible locations are:
- Upper area of the device module: This may apply for e.g. Spartan Sport WHR and Suunto 9.
- Lower area of the device module: This may apply for e.g. Suunto 3 Fitness, Suunto 5, Spartan Trainer, Spartan Ultra and Ambit3 Peak.
- Product information gauge surrounding the product name: Usually it is the first number on the right side of the gauge. This may apply for e.g. Suunto Ambit3 Vertical, Suunto Traverse and Traverse Alpha.
- Middle area of the device module: This may apply for e.g. Suunto Elementum Terra and Suunto EON Core.
In some cases, the serial number may be surrounded by a box. This may apply for e.g. Suunto Ambit3 Peak and Sport, Ambit 2 R Suunto Spartan watches, Suunto 9.
2) On the sleeve of the product box
The serial number is added on a sticker to the product box sleeve as one of the last steps when packaging your product.
Usually all information on the box sleeve is printed directly on the sleeve, only the serial number is added as sticker.
In addition to the serial number, you will find several other numbers externally printed on your Suunto device and the product box which are NOT the serial number:
- Sales item code: SS050209000
- Product name: Suunto 3 Fitness Copper
- Device model ID: OW175
- Radio certifications: IC:5175A-2478 and FCC ID:RYP2478
- Water-resistance marking e.g. 100M-300FT-10BAR
3) In the Settings menu of your watch
In Spartan Collection watches, Suunto 9 and Suunto 3 Fitness you can find the serial number in the watch under Settings > General > About > Serial number.
