FREE SHIPPING OVER Kn 750 SIGN UP FOR NEWSLETTER
Suunto 9 User Guide - 2.1
  • Sunrise and sunset alarms
The sunrise/sunset alarms in your Suunto 9 are adaptive alarms based on your location. Instead of setting a fixed time, you set the alarm for how much in advance you want to be alerted before the actual sunrise or sunset.
The sunrise and sunset times are determined via GPS, so your watch relies on the GPS data from the last time you used GPS.
To set sunset/sunrise alarms:
  1. Press the middle button to open the shortcut menu.
  2. Scroll down to Alarms and enter by pressing the middle button.
  3. Scroll to the alarm that you want to set and select by pressing the middle button.
    SunriseSunset alarm toggle Spartan
  4. Set the desired hours prior to sunrise/sunset by scrolling up/down with the upper and lower buttons and confirming with the middle button.
  5. Set minutes in the same way.
    Time before sunset sunrise Spartan
  6. Press the middle button to confirm and exit.
A watch face is also availalbe that shows sunrise and sunset times.
Outdoor Watchface Spartan
Sunrise and sunset times and alarms require a GPS fix. The times are blank until GPS data is available.
