FREE SHIPPING FROM Kn 750 | EASY RETURNS | SIGN UP FOR NEWSLETTER
How do I pair my Suunto Ambit3, Traverse or Traverse Alpha with Suunto app for iOS?
To start the pairing process, make sure you have the following:
  • a connection to the Internet: Wifi Wifi.png or mobile data Connect.png
  • the latest software of the watch – in case you have issues check some tips here.
The following steps should help you enable the connection between the app & your watch:
  1. Once you are done reading this, go back to the main screen of the app.
  3. Suunto app will ask for notification and optimization permissions, select them according to your needs and desired privacy settings.
The phone will start looking for your watch. The trick is to make the device visible to the app:
  1. Initiate the pairing process on your watch:
Traverse: Long press the middle button - Connectivity - Pair and select MobileApp.
Ambit3: Long press the middle button - Pair and select MobileApp.
The watch should now be visible in the app (identify the watch via serial number – check the back of your watch to make sure you are connecting the correct one) and press PAIR.
  1. Your watch will generate a code. Enter the code in the required field on your iPhone.
  2. The first pairing might take a few minutes.
Note: After a few minutes of inactivity, your Ambit3 / Traverse will activate the power saving mode which will turn off Bluetooth and pause the sync. The log synchronization will continue once you wake up your watch.
RELATED ARTICLES
