Suunto Nautic User Guide
Tank pressure
Once your Suunto Nautic is linked to a Suunto Tank POD, you can follow the tank pressure in the switch window.
If you have not paired a Suunto Tank POD, the switch window tank pressure will read No Tank Pod. If A Tank POD is paired but no data is being received, the field shows - -. This may be because the POD is not in range, the tank is closed, or the POD battery is low.
LED lights may interfere with the Tank pressure signal.
