NEW! WE NOW SHIP TO PORTUGAL | HELLO WINTER 2021 | EASY RETURNS
SUUNTO ACCESSORY STRAPS
Give your Suunto watch a new look with an accessory strap.
Our collection features straps for different activities in a wide range of designs, all easy to change without any additional tools.
To see if your watch is compatible with our quick release straps, see the full accessory strap collection.
See all
HOW TO CHANGE THE QUICK RELEASE STRAP
Suunto accessory straps with quick release mechanism are easy to change without any additional tools. To detach a strap, pull the spring on the underside of the strap to release the pin and remove the strap. To attach a new strap, first insert the pin on the opposite end to the spring mechanism into its socket, then pull the spring and slip the other end into place. Release the spring and check that the pin goes all the way into the socket. You can also pull the strap gently to ensure the strap is in place.
Read more
CARE FOR YOUR WATCH
We recommend treating your Suunto watch just like any other part of your wardrobe. Get a spare strap or two for your watch, change them depending on what you are wearing or doing, and wash the watch body and the straps regularly.
Read more
SEE ALL SUUNTO WATCH STRAPS
See more
