Suunto EON Steel User Guide 3.0
Suunto app
With the Suunto app, you can easily customize device and dive settings. See Customizing dive modes with Suunto app and How to customize dive modes with Suunto app.
You can also transfer your dive logs wirelessly to the app where you can follow and share your diving adventures.
To pair with Suunto app on iOS:
  1. Download and install Suunto app on your compatible Apple device from the App Store. The app description includes the latest compatibility information.
  2. Start Suunto app and turn on Bluetooth if it is not on already. Leave the app running in the foreground.
  3. If you have not yet set up your Suunto EON Steel, do so now (see Device setup).
  4. Tap the watch icon in the upper left corner of the screen and tap on the ' + ' icon to add a new device.
  5. Select your dive computer from the list of found devices, tap PAIR.
  6. Enter the passkey shown on your dive computer display into the pairing request field on your mobile device.
  7. Tap PAIR at the bottom of the request field.
To pair with Suunto app on Android:
  1. Download and install Suunto app on your compatible Android device from Google Play. The app description includes the latest compatibility information.
  4. Tap the watch icon in the upper right corner of the screen.
  5. Select your dive computer from the list of found devices and tap PAIR.
You cannot pair any device if airplane mode is on. Turn off airplane mode before pairing.
Synchronizing logs and settings
To be able to synchronize logs and settings, first you need to install Suunto app.
To download logs from your Suunto EON Steel and sync settings:
  1. Connect Suunto EON Steel to your mobile device via Bluetooth.
  2. Start Suunto app.
  3. Wait for the syncing to complete.
New dive logs appear in your activity history, sorted by date and time.
