Suunto Run User Guide
- Adjusting settings
Adjusting settings
You can adjust all watch settings directly in the watch.
To adjust a setting:
- From watch face, keep the crown pressed to open Settings.
Scroll through the settings menu by swiping up/down or turning the crown.
Select a setting by tapping the setting name or pressing the crown when the setting is highlighted. Go back in the menu by swiping right or pressing the lower button.
- For settings with a value range, change the value by swiping up/down or turning the crown.
For settings with just two values, such as on or off, change the value by tapping the setting or by pressing the crown.
