HRV and Recovery: How to Read Your Heart Rate Variability
SuuntoRun — 11 September 2026
Heart rate variability (HRV) is a helpful metric for endurance athletes. Read on to learn why there’s a buzz around it and how to use Suunto to track heart rate variability.
You’re training consistently, but your times have stalled, or you finish a hard session and still feel flat two days later. Recovery is usually the missing piece, and heart rate variability (HRV) is one of the clearest windows into it.
HRV measures the tiny differences in timing between your heartbeats. Those differences reflect the balance of your autonomic nervous system, which governs how you handle stress, effort, and rest. Tracked over time, HRV tells you whether your body is absorbing your training or quietly asking for a break.
A compatible Suunto watch measures your HRV while you sleep and compares it against your own baseline. That comparison of recent HRV versus your personal normal range is what turns a raw number into a decision: push on with a hard session, or ease off and recover.
The short version
  • HRV is the variation in time between consecutive heartbeats, measured in milliseconds.
  • A single reading tells you little; your personal trend is what matters.
  • HRV below your usual range often points to incomplete recovery.
  • Unusually high HRV isn’t automatically good news either. Read it in context.
  • Suunto tracks HRV during sleep and compares it to the normal range it builds for you.
What is HRV?
HRV, or heart rate variability, is the variation in time between one heartbeat and the next. Even at a steady 60 beats per minute, your heart doesn’t tick like a metronome. One interval might be 0.95 seconds, the next 1.05, the next 0.98. Those millisecond-level differences are normal, and they partly reflect your autonomic nervous system at work.
That system has two sides that pull in opposite directions:
  1. The sympathetic branch: revs you up in response to stress, effort, or a demanding situation.
  2. The parasympathetic branch: brings you back down, supporting rest and recovery.
Higher HRV is often linked to better recovery, but it’s not an absolute rule. Age, fitness, sleep, stress, illness, travel, and training load all move the number around. The most reliable approach is to follow your own trend rather than compare your figure with someone else’s.
Heart rate vs HRV: what’s the difference?
Heart rate tells you how many times your heart beats per minute. HRV tells you how much the spacing between those beats varies.
Indicateur Ce qu’il mesure Exemple
Fréquence cardiaque Nombre de battements par minute 60 bpm
VFC Variation du temps entre deux battements 35 ms, 50 ms, 80 ms
Two people can share the same resting heart rate and have very different HRV, and that doesn’t mean one recovers better than the other. The question that matters is whether your current value fits your own usual range.
Why nighttime HRV matters most
Nighttime HRV is so useful because it’s captured during rest. Through the day, caffeine, meals, training, stress, travel, and even a change of posture all nudge your HRV around. At night, conditions settle, so a sleep measurement gives you a much cleaner read on your recovery trend.
Measured this way, HRV helps answer the practical questions every athlete asks:
  • Have I recovered from my last session?
  • Is my training load creeping too high?
  • Is my sleep actually supporting my recovery?
  • Should I hold today’s intensity or take it easier?
  • Is my body adapting, or starting to fatigue?
That’s why compatible Suunto watches track HRV during sleep: the nighttime signal is judged against your own trend, not a one-size-fits-all number.
How Suunto tracks your HRV overnight
Wear a compatible Suunto watch to bed with sleep tracking enabled, and it measures your HRV through the night. From those readings it builds a personal normal range, then assesses your recovery by comparing your recent average against that range.
This personal baseline is the whole point, because HRV is so individual. A reading of 35 ms might be perfectly normal for one person while another typically sits near 80 ms. What counts is the gap between today’s measurement and your own trend.
So if your 7-day average stays inside your normal range, recovery looks stable. If it sits below the range for a while, your body may need more rest. And if it jumps well above your usual trend, that’s worth a closer look before you add load.
Suunto HRV recovery tracking screen showing 7-day average HRV, last-night HRV and personal normal range.
RMSSD: the metric behind the number
HRV can be quantified in several ways, but for recovery tracking most sports watches lean on nighttime readings and an indicator called RMSSD (root mean square of successive differences).
Without wading into the math, RMSSD looks at the successive changes between heartbeats and picks up shifts in your autonomic nervous system, especially during rest and sleep. For athletes, it’s a good reflection of how the body bounces back after training, stress, or a heavy physical load, which makes it well suited to overnight HRV tracking.
How to check your HRV with Suunto
  1. Wear your Suunto watch overnight.
  2. Turn on sleep tracking.
  3. Sync with the Suunto app when you wake up.
  4. Check your HRV on the watch or in the Training Zone section of the app.
  5. Keep wearing it regularly so your personal normal range sharpens over time.
The more nighttime data you gather, the more meaningful the interpretation becomes.
Reading your HRV status in the Suunto app
In the app, HRV status gives you a quick sense of whether your recovery is holding steady or drifting from its usual pattern. Depending on where your recent HRV sits relative to your normal range, it may show that recovery is stable, that your body is adapting, or that easing the load would be wise.
Low HRV can flag incomplete recovery, but a sudden spike shouldn’t be read as a green light on its own. In both cases, watch the trend across several days and factor in how you actually feel.
Suunto app HRV status view showing current HRV, normal range and HRV trend.
What counts as a “normal” HRV in ms?
There isn’t one. HRV depends on age, fitness, sleep, stress, genetics, lifestyle, and personal history, so an isolated number means very little out of context. An HRV of 30 ms could be entirely normal for one person and low for another.
A few principles worth remembering:
  • Good HRV is, first and foremost, HRV that matches your personal normal range.
  • 30 ms isn’t “bad” if it lines up with your history.
  • Low HRV can reflect fatigue, stress, short sleep, or a heavy training load.
  • High HRV is often positive, but an unusual jump deserves a second look.
  • A trend across several days beats any single measurement.
In short, read HRV as a personal trend, not a universal score.
How to interpret low, normal, and high HRV
HRV is individual, but a few common scenarios help you spot the broad patterns.
HRV result Likely meaning Possible causes How to adapt
Lower than usual Fatigue, stress, or incomplete recovery Hard session, poor sleep, stress, alcohol, travel, early illness Reduce intensity or plan an easier day
Within your normal range Your body’s usual response Stable recovery, controlled load Keep the planned session if you feel good
Slightly higher than usual Potentially strong recovery Rest, good sleep, well-absorbed load Consider a harder session if everything feels right
Very high or unusual An atypical response Accumulated fatigue, routine change, stress, or heavy unloading Check other signals before adding load
Treat this as a guide, not a verdict. Your real state also depends on how you feel, your sleep, your resting heart rate, and your recent training.
Low HRV usually means your body is carrying a real load. It often shows up after an intense session, a race, a rough night’s sleep, or a stressful stretch. Common culprits include:
  • A long or intense training session
  • Accumulated fatigue
  • Too little or poor-quality sleep
  • Significant mental stress
  • Alcohol
  • Dehydration
  • Travel or a change in routine
  • The early stages of illness
  • A training load that’s stayed too high for several days
A temporary dip after a long run, an interval session, or a hard race is completely normal; it simply reflects the effort you put in. But if your HRV stays below your normal range for several days, it’s worth acting on:
  • Dial back the intensity.
  • Swap a hard interval session for an easy run, ride, or recovery day.
  • Add a rest day.
  • Prioritise sleep duration and regularity.
  • Hydrate better.
  • Skip alcohol during heavy training blocks.
Prolonged low HRV often travels with other signs too: heavier fatigue, flagging motivation, slower recovery, and less consistent performance.
High HRV: always a good sign?
Often, yes. If your HRV is a touch above normal and you feel rested, motivated, and energetic, that’s a positive signal. But an unusually high reading, one that leaps well above your trend, doesn’t automatically mean you should pile on load. It can reflect a strong recovery swing known as a parasympathetic rebound, especially after a period of fatigue, stress, or heavy training.
To read it accurately, check the context:
  • Did you sleep well?
  • Is your resting heart rate where it usually is?
  • Do you genuinely feel rested?
  • Have you recently ramped up your training?
  • Have you travelled or changed your routine?
  • Has the rise lasted several days, or just one night?
The aim isn’t to chase the highest possible HRV. It’s to keep a stable trend that matches your overall state.
HRV, sleep, and training load: read them together
HRV means the most in context. A short dip might just mark a tough session. A repeated dip alongside poor sleep and unusual fatigue is a clearer call for recovery. To avoid misreading the signal, keep an eye on the whole picture:
  • Your nighttime HRV
  • Sleep duration and quality
  • Resting heart rate
  • Recent training load
  • How you feel: energy, motivation, muscle fatigue
You don’t need to dissect each one every day. Together, they explain why your HRV rises or falls.
suunto-app-sleep-and-recovery
Putting HRV to work in daily training
HRV is most useful as a simple reference point in your routine, not a number to obsess over.
1. Wear your watch every night
Consistency is everything. The more regular your measurements, the more reliable your personal normal range.
2. Check it in the morning
Morning is the natural moment to glance at your HRV status before you commit to the day’s intensity.
3. Compare it with recent sessions
After an intense session, a long run, or a race, watch how your HRV responds. Over time you’ll learn your body’s patterns.
4. Ease off when it stays low
Several low days in a row? Choose an easy session, a recovery jog or ride, a brisk walk, or a full rest day.
5. Space out your hard sessions
HRV helps you avoid stacking demanding workouts when your body is already showing fatigue.
6. Follow trends, not single nights
One reading shouldn’t rewrite your plan. Patterns across days and weeks are what count.
How to improve your HRV
You can’t force HRV up directly, but you can improve the conditions that support recovery.
Sleep more consistently
Sleep regularity is one of the biggest levers. Keep your bedtimes and wake times reasonably steady, especially during heavy training.
Adapt your training load
Too much load for too many days pushes HRV down. Alternate hard sessions, easy sessions, and recovery days.
Avoid intense sessions late at night
Hard evening training can disrupt sleep and delay your nervous system’s return to calm.
Limit alcohol and stay hydrated
Alcohol disrupts sleep and nighttime HRV. Good hydration, particularly after training or in the heat, supports recovery too.
Manage stress
Mental stress shows up in HRV. Simple habits like breathing, walking, reading, or meditation help your body settle.
Why HRV matters for endurance training
For runners, trail runners, cyclists, and triathletes, progress lives in the balance between load and recovery. You need enough training stress to trigger adaptation, and enough rest to avoid digging a hole. HRV adds context to that balancing act.
In marathon training, a sustained drop can be the hint that a lighter week will pay off. In trail running, it helps you see how your body is coping with long days, big vertical, and back-to-back sessions. For cyclists, it adds nuance to muscle feel and load data. For triathletes, it helps you monitor fatigue building across three disciplines.
And it isn’t just for pros. Any regular endurance athlete can use HRV to understand their recovery better and avoid overdoing it.
Suunto watches with HRV tracking
Overnight HRV measurement is available across compatible Suunto watches, each connecting to the Suunto app so you can follow your recovery trends and fine-tune your training.
Suunto model Key features
Suunto Vertical 2 Latest flagship adventure model, built for long-distance exploration with GPS, an LED flashlight, and up to 65 hours of battery life.
Suunto Vertical Long-distance model with up to 60 days of battery life and offline maps.
Suunto Race 2 Latest flagship race watch with high-precision sensors and a 1.5-inch AMOLED display.
Suunto Race S Compact, high-performance model with AI Coach integration for adaptive training plans.
Suunto Race Performance watch with HRV tracking, coaching features, and navigation.
Suunto Run Lightweight running watch at 36 g, with HRV and sleep tracking.
Suunto Ocean Multisport watch combining dive and sport features, built for performance in and out of the water.
Suunto 9 Peak Pro Durable, slim outdoor watch built for reliable sport performance.
Explore Suunto watches with HRV tracking and find the model that fits your training.
Common mistakes when reading HRV
Comparing your HRV with other people’s
HRV is deeply individual. Your normal can differ from a friend’s even if you’re the same age and similar fitness.
Overreacting to a single night
One dip or spike is normal. Trends across several days carry far more weight.
Assuming higher is always better
High HRV can be positive, but an unusual jump deserves careful reading.
Ignoring how you feel
HRV is a useful signal, not a replacement for your own sense of sleep, energy, and training experience.
The takeaway
HRV is a genuinely useful window into recovery, as long as you read it as a personal trend rather than a score to max out. A single value never tells the whole story.
With a compatible Suunto watch, you can track your nighttime HRV, learn your normal range, and adjust your training day by day. The goal isn’t a perfect number; it’s a better read on your body’s signals.
Discover Suunto watches with HRV tracking and let your recovery data guide your training with more precision.
