A weekly running plan decides more than how many days you run. It matches different types of workouts to your goals and builds in enough time to recover. Whether you’re building a running habit, chasing a faster 5K or 10K, or preparing for a half or full marathon, a well-structured week balances training and recovery.
Our guide covers what a weekly running plan includes, how to build one around your needs, example plans by goal, and how to adjust when life gets in the way.
What Should a Weekly Running Plan Include?
Typically, a weekly plan combines running workouts, supplementary training, and recovery. You don’t need every type of workout every week.
- Easy runs: Help build weekly mileage and develop aerobic endurance.
- Long runs: The longest run of the week in terms of duration or distance, primarily aimed at developing aerobic endurance and the ability to sustain running over longer periods.
- Quality workouts: In this article, this mainly refers to workouts with specific intensity targets, such as tempo runs and interval training. Choose them based on your training goals.
- Rest and recovery: Plan these alongside your running days rather than trying to find room for them after filling your schedule with workouts.
- Supplementary training: May include strength training. More advanced options, such as plyometric training, can be added as needed.
How to Build a Weekly Running Plan That Fits You
To build a weekly running plan, start with your training background, goals, and available time, then decide which workouts to include and when to schedule them. These three steps turn those factors into a practical week.
Step 1: Set Your Training Frequency and Types
Review how many runs you actually completed over the past two to three weeks. Then weigh your goals and available time to decide how often you can run consistently. Next, choose workout types that suit your current stage: easy runs and long runs, plus intervals, tempo runs, or hill workouts depending on your goals.
Use a sustainable training frequency as your starting point, and choose workout types that serve a clear purpose. You don’t need every type of workout in the same week.
Step 2: Set the Intensity and Duration of Each Run
Determine the intensity and duration of each workout. Easy runs should feel comfortable, while quality workouts need intensity and work durations that match their goals. Set your long run’s distance or duration based on your current training background.
When planning each workout, consider how intensity and duration relate for that type of training. Keep every run from becoming a high-intensity session, and keep any single workout within what your current fitness can handle.
Step 3: Check Your Overall Weekly Training Load
Assign each workout to a specific day, taking your work, daily life, and recovery needs into account, and consider how the sessions fit together across the week. Add supplementary activities such as strength training and mobility exercises, and make sure the week’s total training time and workload are manageable.
Once you have a draft schedule, compare it with what you actually completed over the past two to three weeks. Check whether your running frequency, total duration, or number of high-intensity sessions has jumped significantly, and adjust the plan if it has.
Weekly Running Plan Examples by Goal
Our examples show how to combine workouts in a typical week for different goals, and they work as general references.
The beginner plan builds a running habit. The other plans suit runners who can already handle a similar training frequency and duration consistently. Choose the approach that fits your recent training and recovery, and when you adjust it, change one main variable at a time so you can see how your body responds.
Weekly Running Plan for Beginners
For beginners, the priority is to establish a regular running habit and adapt gradually to the demands of running. Combining running and walking lets you start with short running intervals and extend your continuous running time as your body responds.
| Day |
Workout |
| Monday |
Rest or easy walking for 20–30 minutes |
| Tuesday |
Run-walk session for 25–30 minutes: warm up with 5 minutes of walking, alternate 1–2 minutes of easy running with 1–2 minutes of walking, then cool down with 5 minutes of walking |
| Wednesday |
Rest or easy walking |
| Thursday |
Repeat Tuesday’s run-walk session, shortening the duration if needed |
| Friday |
Rest |
| Saturday |
Repeat the run-walk session you have already adapted to |
| Sunday |
If you can run only three days a week, keep one quality workout, one easy run, and one longer easy run, and rotate the type of quality workout from week to week. Runners who are used to two quality sessions a week and recover well can replace Thursday’s easy run with a second quality workout.
Weekly Running Plan for a Half Marathon
The following example includes four running days per week, with one tempo workout and one long run as the key sessions. The remaining runs are kept at an easy intensity.
| Day |
Workout |
| Monday |
Rest, or easy walking and stretching |
| Tuesday |
Easy run for 40–50 minutes |
| Wednesday |
Tempo run: after warming up, complete 3 × 8 minutes at tempo pace, with 2–3 minutes of easy jogging between intervals, followed by an easy cooldown |
| Thursday |
Rest, or 30–45 minutes of easy cycling, swimming, or walking |
| Friday |
Easy run for 30–45 minutes, with an optional short session of familiar strength exercises |
| Saturday |
Rest |
| Sunday |
Easy long run for 75–120 minutes |
If you can only run three days a week, remove one easy run while keeping the tempo run, one easy run, and the long run. If you want to include a steady-paced segment toward the end of your long run, treat it as additional training load rather than automatically adding it to your weekly schedule.
Weekly Running Plan for a Marathon
The following example provides a weekly structure for marathon preparation, with an emphasis on long runs and practicing fueling, hydration, and equipment. The duration of midweek runs and long runs should be adjusted to your current training phase rather than following fixed values that apply to everyone.
| Day |
Workout |
| Monday |
Complete rest or easy walking |
| Tuesday |
Easy run for 45–60 minutes, with optional familiar strength training |
| Wednesday |
Moderate-length easy run, with duration based on recent sessions of a similar type |
| Thursday |
Easy run for 30–50 minutes, or low-impact cross-training such as easy cycling or swimming |
| Friday |
Rest or light activity to prepare for the long run |
| Saturday |
Long run: set the duration according to the long-run duration you have already adapted to and your current training phase. Practice fueling, hydration, equipment, and pacing |
| Sunday |
Recovery run for 20–40 minutes, or walking or rest depending on how your body responds |
When adding marathon-pace practice, replace part of Wednesday's easy run rather than simply stacking another workout onto the existing plan. For example, after warming up, complete 2 × 15 minutes at marathon pace, with 5 minutes of easy jogging between intervals, followed by an easy cooldown. Your training cycle should also include cutback weeks with reduced training volume to avoid increasing the workload every week.
How to Adjust Your Running Week When Plans Change
When fatigue or unexpected commitments disrupt your schedule, you don’t need to make up every missed workout. Assess how you’re feeling first, then decide which sessions to keep, shorten, reschedule, or skip.
When Fatigue Changes the Plan
Use the following guidelines to decide whether to adjust your training:
- Feeling about the same as usual: Follow your original plan and pay attention to how your body responds during the run.
- Feeling more tired than usual: Reassess after warming up. You can shorten the workout, reduce the number of repetitions, or replace a quality workout with an easy run. If you don't feel better, cancel the session.
- Fatigue continues to build: If you also experience consistently poorer sleep or soreness that doesn't resolve, reduce your training load and allow more time for recovery.
- Warning signs appear: Stop training and seek an appropriate medical assessment if pain worsens or affects your gait, or if you experience unusual symptoms such as chest pain or dizziness.
When You Miss a Run
If you miss a workout, there's no need to rush to make it up or compensate by increasing the duration or intensity of other sessions. First consider whether you missed an easy run or a quality workout, then decide whether to skip it or reschedule it.
- Missed an easy run: You can generally skip it and continue with the rest of your plan.
- Missed a quality workout: Consider rescheduling it only if doing so won't crowd out other key workouts or recovery time. If rescheduling would concentrate too many demanding sessions together, skip that workout.
How to Use Suunto to Guide Your Weekly Running Plan
- Before your run: Create a structured workout in the Suunto app ahead of time, setting up the warm-up, work intervals, recovery intervals, and cooldown, then sync it to a compatible watch. If you plan to use route navigation, you can plan your route in advance, check the distance and elevation gain, and make sure the route has synced.
- During your run: Follow the purpose of the day's workout without needing to use every feature at once. Structured workout prompts can guide you through each stage, while route navigation can be enabled when needed. For easy runs, sustained tempo runs, or longer intervals, you can refer to ZoneSense to check whether your actual intensity matches the workout's purpose. For long runs or marathon-specific training, EnergySense can show your estimated sustainable distance and remaining energy at your current effort level, helping you decide whether to slow down rather than focusing only on your target pace.
- After your run: Once you've finished and synced your activity, review your weekly training load and intensity distribution in Training Zone. Consider these alongside recent sleep, heart rate variability (HRV), and how you feel to assess whether your training demands are aligned with your recovery.
If you use a Suunto Race 3S, you can also ask Suunto AI Coach questions about these records to better understand recent changes and decide whether to maintain your current schedule, shorten workouts, reduce intensity, or add more rest in the following week.
Takeaways
A good weekly running plan leaves you willing and able to keep training the following week. Start with a schedule you can complete consistently, prioritize the key workouts that support your goals, and complement them with easy runs and rest.
Adjust duration or frequency gradually as you adapt, and lower your workload when life gets busier. By building in recovery, reviewing your progress, and following through each week, you can turn consistent daily effort into long-term progress.
Good luck in your training!
FAQ
How Many Days a Week Should I Run?
Start with three days per week, then let how often you can train consistently and recover fully set your actual frequency. Once you’ve adapted, consider moving to four or five days, with most added sessions kept easy.
Can I Do Intervals and a Long Run in the Same Week?
Yes, as long as the combined training load suits your current fitness and you leave easy running or rest days between the two sessions.
Should I Do Tempo Runs and Intervals Every Week?
Not necessarily. Choose one based on your goals or alternate between them week to week. Only runners who are already used to two quality workouts per week and recover well should include both in the same week.
