Your watch says you climbed 500 ft on today's run. Is that a lot? On a 5K, this amount of climbing indicates significant elevation changes. But over the distance of a full marathon, the average elevation gain per kilometer is much lower, so the route may feel relatively less hilly overall.
To read this number properly, you first need to know what it measures. This guide covers how elevation gain is defined and calculated, how to use it to judge a route, and how it shapes your running performance.
Table of Contents
What Is Elevation Gain in Running?
In running, Elevation Gain refers to the total vertical distance gained across all uphill sections during a run. It is also known as Total Ascent or Cumulative Elevation Gain. The term "cumulative" means that the elevation gained on each uphill section is added together, while downhill sections do not subtract from the total. Therefore, elevation gain is not the same as the difference in elevation between the starting and finishing points.
For example, imagine a route that starts at an elevation of 100 m, climbs to 200 m, descends to 150 m, and then climbs again to 250 m. Each of the two uphill sections gains 100 m, giving the route a total elevation gain of 200 m, rather than the 150 m difference between the starting and finishing elevations.
Understanding Related Elevation Terms
When reviewing your running records or a race course, you may come across several terms besides elevation gain. Each describes elevation information from a different perspective:
| Term | Meaning | Example |
| Elevation / Altitude | The height of a location above sea level | The starting elevation is 100 m, and the finishing elevation is 250 m |
| Elevation Loss / Total Descent | The total vertical distance lost across all downhill sections | A descent from 200 m to 150 m gives a total descent of 50 m |
| Net Elevation Change | The difference between the finishing and starting elevations | 250 m − 100 m = +150 m |
These figures are also often displayed alongside an Elevation Profile. This graph uses route distance on the horizontal axis and elevation on the vertical axis, showing where the uphill and downhill sections occur rather than just giving you the total elevation gain.
How Is Elevation Gain Measured and Expressed
Sports watches and running apps calculate elevation gain by adding together the elevation gained across different sections of a route. Common data sources include GPS, barometric altimeters, and digital map elevation data.
Measurement results can vary depending on the data source and processing method. GPS elevation readings can be affected by signal quality and surrounding conditions, while barometric readings may fluctuate with changes in weather and atmospheric pressure. Different platforms may also use different correction or smoothing algorithms. As a result, the elevation gain recorded for the same route may not be exactly the same across devices or platforms. When comparing everyday training records, try to use the same device or platform to keep your measurements consistent.
Elevation gain is generally expressed in two ways:
- Total Elevation Gain: Expressed in ft (feet) or m (meters), this indicates how much vertical distance you've gained over the entire route.
- Elevation Gain per Unit Distance: Expressed in ft/mile (feet per mile) or m/km (meters per kilometer), this indicates the average elevation gained per mile or kilometer, making it easier to compare routes of different lengths.
How Much Elevation Gain Is a Lot for Running?
To determine whether an elevation gain is significant, you need to consider it in relation to the route distance. The course specifications published by World Athletics for the World Mountain and Trail Running Championships provide useful reference points. The following table shows the official distance and elevation gain requirements for different race categories:
| Race Category | Course Distance | Elevation Gain | Elevation Gain per Unit Distance |
| Senior Classic (Up and Down) | 12–15 km | 600–900 m | 40–75 m/km |
| Short Trail | 35–45 km | 2,000–3,000 m | 44–86 m/km |
| Long Trail | 75–85 km | 3,500–6,000 m | 41–80 m/km |
Note: Elevation gain per unit distance is calculated from the endpoints of the official distance and elevation gain ranges. It indicates a possible range of values, not the actual distribution across race courses.
These figures help illustrate the elevation gain involved in mountain and trail running events, but they should not be used as fixed difficulty thresholds for everyday running routes. For example, suppose your usual 10 km run has about 50 m of elevation gain, while a new route of the same distance has 200 m. Your average elevation gain per kilometer has increased from 5 m to 20 m. Although both figures are below the race reference ranges in the table, the new route has four times the elevation gain of your usual run, making it worth considering in advance. This comparison reflects the amount of climbing, not a fourfold increase in actual difficulty.
What Flat, Rolling, Hilly and Mountainous Mean
In addition to elevation data, you'll often see descriptions such as Flat, Rolling, Hilly, and Mountainous in route guides. These terms summarize a route's overall characteristics and are not used here as categories with fixed numerical thresholds:
- Flat: Relatively little elevation change, with few significant climbs.
- Rolling: Repeated small climbs and descents throughout the route.
- Hilly: More pronounced climbs and descents, with uphill sections forming a major feature of the route.
- Mountainous: Emphasizes the mountain environment and overall terrain characteristics, rather than just the total elevation gain.
Other Factors That Affect Route Difficulty
Total elevation gain and general route descriptions provide an overall picture, but they don't capture the characteristics of every section. Even when two routes have similar distances and elevation gains, you should also consider the following factors:
- Gradient and Climb Length: The same amount of elevation gain can be concentrated in short, steep climbs or spread across longer, gentler slopes. Consider the characteristics of individual sections.
- Elevation Gain Distribution: Check whether the main climbs are concentrated in the first half, the second half, or spread throughout the route.
- Descents and Terrain: Steep downhill sections and surfaces such as rocks and mud should also be taken into account when assessing a route.
How Elevation Gain Affects Running Metrics and Performance
Elevation gain affects not only your speed and output on uphill sections but also how you perform on subsequent sections as fatigue builds. The following metrics can help you better understand these changes.
- Pace: Maintaining your flat-ground pace on an uphill section typically requires more energy, so you'll often need to slow down deliberately. A drop in pace doesn't necessarily mean your performance is declining; it may simply reflect an effort to manage your intensity. As fatigue builds, you may also find it harder to return to your previous pace on later flat or uphill sections.
- Running Power: Power helps you track changes in output across different terrain. If you try to maintain your flat-ground pace while running uphill, you'll generally need to produce more power. If you want to keep your output within a planned range, you'll need to adjust by slowing down.
- Heart Rate: Sustained climbing increases your body's energy demands, which may cause your heart rate to rise. Even after you slow down, your heart rate may remain elevated for some time. Monitoring these changes can help you assess whether your current workload is higher than expected.
- RPE: As your breathing quickens and leg fatigue increases, your perceived effort may gradually rise even if your pace or power remains relatively consistent. This is particularly relevant during sustained climbs or the later stages of a long run. Use RPE to help determine whether you need to further adjust your speed and output.
When assessing your performance on a route with significant elevation gain, consider pace, power, heart rate, and perceived effort together. Pay particular attention to whether you can maintain your planned output and rhythm as fatigue accumulates.
How to Train for Routes With More Elevation Gain
When preparing for routes with significant elevation gain, your training should focus not only on the total amount of climbing but also on replicating the uphill and downhill characteristics of your target route. This helps your body gradually adapt to the energy demands of sustained climbing and the muscular stress of descending.
Match Your Training to the Route Profile
Start by reviewing the elevation profile of your target route and identifying its main uphill and downhill sections. Then choose your training focus based on the route's characteristics:
- Long, Sustained Climbs: Include sustained uphill runs to practice managing your intensity and maintaining steady output over longer periods. If you don't have access to natural hills, you can use a treadmill with an incline setting. For steeper trail sections, you can also practice Power Hiking, which involves walking uphill at a brisk, deliberate pace with shorter steps. Try running and power hiking on the same hill, then compare your completion time, breathing, and perceived leg effort to gradually find the right strategy for switching between running and walking.
- Multiple Short Climbs and Rolling Terrain: Use hill interval training to practice controlling your output during repeated climbs. You can also incorporate uphill, downhill, and flat sections into a rolling long run to practice transitioning between different types of terrain. Gradually choose training routes that more closely match the length and distribution of the main climbs on your target course.
- Sustained Descents and Technical Terrain: Start with short, gentle descents on predictable surfaces. Practice controlled pacing, foot placement, and braking, then gradually increase the length of the downhill sections and the complexity of the terrain. After adding downhill training, adjust your subsequent workouts based on muscle fatigue and recovery.
You can also incorporate lower-body strength training based on your current fitness level. Runners with an appropriate training background can gradually add plyometric exercises, such as jumps, to complement their running-specific workouts.
When increasing training load, adjust distance, elevation gain, and intensity gradually. Be sure to allow enough recovery time, especially when adding more downhill running and supplementary exercises.
Plan and Review Your Training With Suunto
If you're using a Suunto sports watch, you can use the Suunto App to review routes and training data, putting these training principles into practice through route planning, in-run adjustments, and post-run analysis.
- Plan Your Route and Workout in Advance: Use the maps and elevation profiles in the Suunto App to check the location, length, and distribution of the main uphill and downhill sections. Choose a route that matches the goal of your workout.
- Follow Your Route and Get Climb Guidance During Training: Sync your route to a watch that supports route navigation to follow it during your run and receive off-route alerts if you stray from the planned course. On models that support Climb Guidance, you can also view information about the current climb to help track your progress through each section.
- Analyze Your Climbing Performance After Training: In the Elevation section of your activity record in the Suunto App, review your uphill performance using Ascent, Ascent duration, and Ascent speed, alongside the corresponding Descent, Descent duration, and Descent speed metrics. Then combine these with Pace, Heart Rate, and any recorded Power data to see whether your speed and output on different sections matched your training goals and whether you maintained the expected intensity later in the run. To take a closer look at your climbs, use the Category-based statistics for Climbs, Ascent, and Duration to compare the number of climbs in each category, their contribution to total elevation gain, and the time spent on them during the workout.
Takeaways
Elevation gain adds information about a route that distance and pace alone cannot fully capture. The same distance can present very different challenges, and a slower pace can still reflect considerable effort.
Understanding this metric ultimately helps you assess routes more accurately and put your performance into context. Whether you're choosing your next running route or preparing for a race with more elevation changes, use elevation gain as a starting point for planning. Then refine your expectations through training and find a pace that works for you.
