Suunto Ambit3 Peak User Guide - 2.5
- Countdown timer
Countdown timer
You can use the countdown timer to count down from a preset time to zero. The timer makes a short sound every second during the last 10 seconds and sounds an alarm when zero is reached.
You can show/hide the countdown timer from the start menu under Displays » Countdown. Toggle with Next.
To set the countdown time:
- Press Next to until you reach the countdown timer display.
- Press View to adjust the countdown time.
- Set the hours and minutes with Start Stop and Light Lock. Accept with Next.
- Press Start Stop to start the countdown.
You can pause/continue the countdown by pressing Start Stop.
