Suunto EON Core User Guide - 2.0
Dive modes
By default, Suunto EON Core has two dive modes: Air / Nitrox and Gauge (bottom timer). Select the appropriate mode for your dive under Dive settings » Mode.
Dive mode EON Core
Air/Nitrox dive mode has one active gas by default. You can edit this gas in the device menu where O2 percentage and pO2 value can be changed. To enable diving with more than one gas, you need to activate multigas diving under Dive settings » Parameters » Multiple gases. After this step you are able to add further gases in the Gases menu. Gas settings can also be customized in Suunto DM5. See Customize dive modes with DM5.
The default dive modes use prominent style. You can change the style and other settings, as well as create additional dive modes using Suunto DM5. See Customize dive modes with DM5.
In DM5 you can create new or edit existing dive modes, modify screen layouts, add helium to enable multigas mode for Trimix, and change dive type (OC/CC).
CCR (closed circuit rebreather) dive support can be activated only using DM5.
The decompression algorithm used in Suunto EON Core is Suunto Fused™ RGBM 2. For more information about the algorithm, see Decompression algorithm.
Gauge is a bottom timer mode and thus has no decompression information or calculation included.
After diving in gauge mode, decompression calculation is locked for 48 hours. If during this time you dive again, there is no decompression calculation available and Locked is shown in decompression information fields.
Air / nitrox mode
By default, air / nitrox mode is for diving with regular air and diving with oxygen enriched gas mixtures.
Diving with nitrox gas mixture allows you to increase bottom times or reduce the risk of decompression illness. However, when the gas mix is altered or depth increased, the oxygen partial pressure is generally increased. Suunto EON Core provides you with information to adjust your dive and stay within safe limits.
When diving with nitrox gas mixture, both the percentage of oxygen in your tank and the oxygen partial pressure limit must be entered into Suunto EON Core.
This ensures correct nitrogen and oxygen calculations and the correct maximum operating depth (MOD), which is based on your entered values.
The default oxygen percentage (O2%) setting is 21% (air) and oxygen partial pressure (pO2) setting is 1.6 bar (20 psi).
Air/ Nitrox mode has two views by default:
  • No deco
    airnitrox nodeco eon
  • Compass
    airnitrox compass eon
After customizing with DM5, two other views are available:
  • Tank Pressure - For more information on what is shown on the display, see Tank pressure .
    airnitrox tank pressure eon
  • Timer
    image:airnitrox timer eon
Gauge mode
Use Suunto EON Core as a bottom timer with Gauge mode.
The timer in the top right of the display shows dive time in minutes and seconds and can be activated and stopped by short pressing the upper button. Keep the upper button pressed to reset timer.
Gauge mode is a bottom timer only and thus includes no decompression information or calculations.
Gauge mode has two views by default:
  • Timer
    Gauge timer eon
  • Compass
    Gauge compass eon
A third view is visible after cutomizing with DM5:
    Gauge tank pressure eon
