Suunto Wing 2 User Guide
Buttons
Suunto Wing 2 has three buttons you can use to switch song, adjust volume and answer or end phone calls.
- multifunction button
- and power button
- button
Switching on/off the device
- keep the button pressed for 3 seconds to switch the device on or off
Listening to audio
press the multifunction button once to start or stop playing the audio
press the multifunction button twice to skip to the next track
press the multifunction button three times to return to the previous track
press the button to increase volume
press the button to decrease volume
keep the multifunction button and the button pressed simultaneously for 3 seconds to switch sound mode
Making a phone call
press the multifunction button once to answer or end a call
Adjusting settings when the device is on
keep the button pressed for 3 seconds to switch the LED lights on
keep the button pressed again for 3 seconds to switch between 5 light modes
keep the multifunction button and the button pressed simultaneously for 3 seconds to enable Head Movement Control
in pairing mode, keep the multifunction button and the button pressed simultaneously for 3 seconds to enable dual device connection
