Suunto Apps
Suunto Apps allow you to further customize your Suunto Ambit3 Vertical. Visit Suunto App Zone under Community in Movescount.com to find Apps, such as various timers and counters, available for your use. If you cannot find what you need, create your own App with Suunto App Designer. You can create Apps, for example, for calculating your estimated marathon result, or the slope grade of your skiing route.
Suunto Apps in Movescount refers to apps you can use in your watch. Not to be confused with Suunto app which is a mobile app used for analyzing and sharing your trainings, connecting to partners and much more.
To add Suunto Apps to your Suunto Ambit3 Vertical:
- Go to the App zone section in Movescount community to browse existing Suunto Apps. To create your own App, select App Designer.
- Add Suunto App to a sport mode. Connect your Suunto Ambit3 Vertical to your Movescount account to synchronize Suunto App to the watch. The added Suunto App will show the result of its calculation while you exercise.
You can add up to five Suunto Apps to each sport mode.
