Compare Suunto 9, Suunto 9 Baro and Suunto Spartan Sport Wrist HR Baro to learn what their differences are and which model is best for you.
When you have your mind set on a certain goal or adventure, you want to make sure your watch can also go the distance. With up to 120 hours of continuous exercise tracking Suunto 9 is built to last – just like you!
See the whole story
The Suunto 9 with a barometer gives you more accurate altitude information because it combines GPS data with barometric altitude information (FusedAlti™). Based on data from the barometer, it also provides outdoor information like sea level air pressure and has a storm alarm. The other Suunto 9 models still deliver altitude information, but they are based on GPS readings.
Measurements | {{ productDimensionsInGrams }} mm / {{ productDimensionsInInches }} " |
Weight | {{ selectedProductSpecifications.ProductWeightGrams }} g / {{ selectedProductSpecifications.ProductWeightOunces }} oz |
Bezel material: | {{ selectedProductSpecifications.BezelMaterial }} |
Glass material: | {{ selectedProductSpecifications.LensMaterial }} |
Case material: | {{ selectedProductSpecifications.CaseMaterial }} |
Strap material: | {{ selectedProductSpecifications.StrapMaterial }} |
What's in the box? |
Metric scales | {{ selectedProductSpecifications.MetricScales }} |
Imperial scales | {{ selectedProductSpecifications.ImperialScales }} |
Balanced for northern hemisphere | |
Balanced for southern hemisphere | |
Declination correction | {{ selectedProductSpecifications.DeclinationCorrection }} |
{{ feature.Name }} {{ feature.TooltipIconText }} | {{ feature.DescriptionToolTipIconText }} |
{{ feature.Name }} {{ feature.TooltipIconText }} | {{ feature.DescriptionToolTipIconText }} {{ feature.DescriptionTooltip }} |
Learn how to install the latest software on your watch using SuuntoLink. Download SuuntoLink
Learn how to use battery modes and prolong battery life during long trainings.
This video shows you step-by-step how to set your personal pace and power zones in the settings menu.
This video shows you step-by-step:
How to activate a power target for exercise.
How to use the real-time guidance within your target during exercise.
How to activate a pace target for exercise.
Learn how to pair your Suunto watch with the Suunto app for iOS and how to get started with the app.
Learn how to pair your Suunto watch with the Suunto app for Android and how to get started with the app.
Clean your Suunto watch regularly with lukewarm water and mild soap.
This review is from
{{ row }}
*Your actual battery life may vary depending on usage and conditions. If you enable the Ultra battery mode it will increase battery life, but deactivate wrist heart rate tracking. In Endurance battery mode, battery life is 40 hours with wrist heart rate and 50 hours with HR belt. Touch is disabled during exercise, but you can activate it in your custom mode.
See accuracy of our data monitoring and accuracy of wrist-based heart rate.
Learn more about the best practices for measuring heart rate from wrist.
{{ comment.Title }}
{{ comment.SubmissionTime | dateToUTCString }}
{{ row }}
{{ row.Date | dateToUTCString }}
{{ response }}{{ row.Name }}
