Threshold Heart Rate Explained: How to Use It for Smarter Training
SuuntoRun — 30 septembre 2026
Heart rate tells endurance athletes how hard they are working. You have probably come across maximum heart rate, resting heart rate and heart rate zones already. As your training gets more structured, threshold heart rate (THR) gives you another useful reference for choosing the right intensity.
Your threshold heart rate shows how your body responds to different training demands. This guide covers what it is, how to find yours and how to use it in everyday training.
What Is Threshold Heart Rate?
Threshold heart rate (THR) is your heart rate when you exercise at threshold intensity. In endurance training, it usually means lactate threshold heart rate (LTHR).
In plain terms, it is your heart rate during a sustained, higher-intensity effort. Runners and cyclists use it to set personal heart rate zones, manage workout intensity and read their training alongside pace or power. It shows how the heart responds when you work near threshold.
A threshold is a transition region, not an on-off switch. As intensity rises, your body shifts gradually from a fairly stable effort toward a more demanding one.
How to Determine Your Threshold Heart Rate?
You can find your THR three ways: a field test, a device estimate or laboratory testing. Field tests and device estimates are the most practical for everyday training, so this section focuses on those two. Lab testing needs specialized equipment and controlled conditions, but it gives a closer look at physiological responses such as changes in blood lactate.
1. Field Test
A 30-minute time trial is a common way to estimate THR. It suits runners who have a solid training base and can hold a hard effort. Using Joe Friel's method, the steps are:
a. Warm up well, then run at the hardest steady effort you can hold for 30 minutes.
b. Record your pace and heart rate the whole way.
c. Take your average heart rate over the final 20 minutes as your estimated THR. For functional threshold pace, use your average pace over the full 30 minutes.
2. Suunto Estimation
Some Suunto sports watches use your training data to estimate THR. You will find the result in the watch’s Progress widget, alongside metrics like VO₂ max and predicted race times. What appears, and how, depends on your model, software version and how much training data you have logged.
You can also run the SuuntoPlus Threshold Test for a structured running test. It uses the heart rate and pace from the session to estimate your LTHR and threshold pace, then you can use the results to set or adjust your training zones.
Pick a route with consistent terrain, steer clear of extreme weather and big elevation changes, and keep your effort steady. One result can be skewed by how you feel that day, so read it alongside your longer-term trends. These estimates guide your training. They do not replace lab testing.
threshold heart rate and pace in progress widget of suunto watch
How to Understand Your Threshold Heart Rate Value?
Say your estimated running THR is 170 bpm. That gives you a reference for running near threshold, based on that test. On its own, the number does not define your fitness, mean every workout should hit 170 bpm, or tell you to stop the moment you go past it.
Start with the test method, the sport and the matching pace or power. Pace and power show your output; breathing and perceived effort tell you how sustainable it is. VO₂ max is your maximum oxygen uptake and FTP is your functional threshold power. Do not convert either one straight into a THR.
To track progress, read heart rate next to output. Say two tests under similar conditions both put your THR around 170 bpm, but your pace improves from 5:00/km to 4:45/km. That points to better performance.
How to Use Threshold Heart Rate?
THR helps you set personal training zones, manage sustained efforts and read performance alongside pace. It works best when your output is steady. During short intervals, or when your condition changes, lean more on pace, power and how the effort feels.
1. Set a Personalized Intensity Reference
Runners hit threshold intensity at different heart rates. The same bpm can feel easy for one runner and put another right at threshold. Testing your own THR gives you a personal reference for setting zones across different workouts.
These zones help you match effort to the session. They keep easy days easy and check that hard efforts stay near the intended intensity. They also stop you getting carried away and creeping faster just because the pace feels good. Adjust to how you feel, and load your zones into a compatible device like Suunto Run 2 so you can check them as you run.
use suunto run 2 in running
2. Control Sustained Hard Efforts
Hard sustained workouts need an effort you can hold to the end of every rep. THR helps you check you are near the planned intensity, but heart rate lags when you speed up. Keep your opening pace in check so you do not go out too fast and fade.
Start a continuous threshold run or a long cruise interval at a manageable pace, and let your heart rate rise into the target range on its own. Then use your breathing and perceived effort to judge whether you can hold it. Do not surge just to reach the target number sooner.
If your heart rate keeps climbing while your pace drops and the effort feels harder and harder, slow down or cut the rep short. Afterward, compare the first and second halves of the session, or the same points in each rep. A clearly slower pace at a similar heart rate late in the workout means you were struggling to hold output. Factor in terrain, weather and fatigue before you read too much into it.
3. Track Progress and Reassess Over Time
Once you have a THR, use it to guide workouts and track performance over time. Watch how it moves alongside pace, power and perceived effort, not just whether the number goes up.
Compare these across several sessions under similar conditions. A faster pace or higher power at a similar THR usually means you are producing more output for the same physiological effort. A lower heart rate at the same pace or power can also point to progress. A higher heart rate with lower output and greater perceived effort tends to reflect fatigue, weather or other conditions.
If a change holds across several workouts, or your zones keep feeling out of step with your effort, retest with the same method and update them. One odd reading or a small swing is not a reason to change anything.
4. Know When Not to Chase Heart Rate
Your THR comes from a test under specific conditions. In training, your heart rate also depends on how fast it responds, your surroundings and your physical state. In these situations, let the workout’s purpose, your pace or power and your perceived effort set the intensity:
  • Short intervals and hill sprints: Hit the prescribed output and duration. Do not push harder just because your heart rate still looks low.
  • Rolling terrain: Do not speed up early in a climb because your heart rate has not caught up yet. After a descent, there is no need to accelerate just to hold the target.
  • Heat or heavy fatigue: If your usual pace feels unusually hard, ease off rather than forcing your normal pace and heart rate.
  • Racing: Set your effort by the distance and your target finish time. In longer races especially, do not push up to THR early.
Racing with Suunto watches
Why Does My Threshold Heart Rate Change?
Your estimated THR can shift with the test method, the sport and the quality of your data. During exercise, your actual heart rate also responds to your surroundings, your physical state and how long you have been going. Knowing why helps you make sense of the numbers.
  • Different tests and devices: Lab tests, field tests and device estimates use different methods, so results can differ. A loose sensor, signal dropouts or bad readings can also throw off the result.
  • Different sports: Test running and cycling separately, and set your zones for each.
  • Different conditions: Temperature, humidity and altitude all affect exercise heart rate, and so do sleep, stress, recovery, illness and caffeine. Keep conditions as similar as you can when you retest, so the comparison means something.
  • Heart rate drift: Over a long effort, your heart rate can creep up even when pace or power holds steady. It is tied to changes like rising body temperature and fluid loss, and it gets worse in the heat. If your heart rate keeps climbing on an easy session, ease the pace and stay on top of hydration and cooling.
Takeaways
Use your THR to set zones that fit your training plan, then adjust your effort by pace and feel. Do not chase a heart rate number at the expense of what the session is for. To judge progress, look for long-term gains under similar conditions, like running faster at the same heart rate, rather than whether the threshold number itself has gone up.
FAQ
Why is my threshold heart rate different from my maximum heart rate?
They measure different things. Maximum heart rate is the highest your heart rate can go. THR is a reference for sustained, higher-intensity work. There is no fixed ratio between them.
Why does my heart rate exceed my threshold during training?
Going briefly above THR is normal in efforts like hard intervals, race surges or hill reps. It guides your intensity; it is not a ceiling for every session.
Is a higher threshold heart rate better?
No. THR varies from person to person and cannot compare athletic ability. Look for gains in threshold pace or power under similar conditions, not a higher heart rate.
How often should I update my threshold heart rate?
Retest when your fitness changes noticeably, or when repeated workouts under similar conditions show your zones no longer fit your effort. A single fluctuation does not call for an update.
Should a 5K be run at threshold pace?
If you are racing for your fastest time, most runners go faster than threshold pace. If the 5K is a threshold workout, holding threshold pace is the point.
Why are my zones different when based on maximum heart rate and LTHR?
The two methods use different reference values and can apply different percentage boundaries. So zones with the same name can represent different intensities. Check which system your training plan uses and match your device settings to it.
