Endurance Training: How to Build Endurance
SuuntoRun — 13 október 2026
Every run starts to feel hard before you get very far, and you keep falling short of your target distance. You want more endurance, but you're not sure how to structure your training. Using running as the example, this guide covers the main types of endurance training, how to build endurance gradually, and how to track your progress.
What Is Endurance Training?
Endurance training is a structured approach to improving your body's ability to sustain activity and resist fatigue. It helps you keep going for longer and hold your performance as fatigue sets in.
Endurance can be viewed through several lenses: physiological function, athletic goals, or how the body produces energy. From a physiological perspective, two types matter most for training:
  • Cardiorespiratory Endurance: The ability of your heart, lungs, and circulatory system to deliver oxygen to working muscles and support sustained activity.
  • Muscular Endurance: The ability of your muscles to contract repeatedly or hold an effort over time. Where muscular strength is about how much force you can produce, muscular endurance is about how long you can sustain an effort or how many repetitions you can complete.
Running, cycling, and swimming draw on both, though the balance varies with the activity and the muscles involved. The sections below cover common endurance training methods so you can find an approach that fits your current fitness level and goals.
What Are Examples of Endurance Training?
Many types of exercise build endurance, and the right choice depends on your current fitness and what you want to improve. Walking, especially brisk walking, is a good starting point for building endurance and a regular exercise habit. If your goal is better running, make running your main activity and use cycling or swimming as complements.
Once you've chosen your main activity, vary your training to target different aspects of endurance. For running, common approaches include:
  • Easy Runs: Build your aerobic base by accumulating training time at a comfortable, sustainable effort. They’re a key part of everyday endurance training.
  • Long Runs: Go longer than your usual runs to practice sustaining activity over an extended period. Focus on gradually increasing duration rather than trying to run faster at the same time.
  • Tempo Runs: Practice maintaining a steady effort that feels challenging but controlled. Tempo runs are often used to develop the ability to sustain efforts near lactate threshold intensity.
  • Interval Training: Break a workout into repeated efforts separated by easier activity or rest. High-intensity interval training (HIIT) is one common form. The main training benefit depends on the intensity and duration of each effort, along with the recovery between intervals.
These methods differ in duration, intensity, and recovery structure. Combine them to suit your goals and use only the ones that serve them. A plan that fits you matters more than one that covers everything.
Building endurance starts with a clear training goal and a routine you can stick with. For running, that means starting with what you can comfortably manage now, then building your ability to sustain effort and hold your pace late in a run through consistent training and gradual adjustments.
Train Consistently
Look at how much time you have each week and pick training days you can stick to. Start with a run duration you can finish comfortably rather than building your plan around a workout that leaves you struggling. If you're new to regular running, begin with fewer sessions, shorter runs, or a run-walk approach. If you already have a running base, build from your current routine rather than making every run the same length.
Run-walk sessions are a good place to start if you're just establishing the habit. Leave time for recovery between training days, too. Here's an example starting week to use as a reference. Adjust it to your fitness level and how your body responds.
  • Monday: Run-walk session. Warm up with a walk, alternate easy running with walking, then finish with a cooldown walk.
  • Tuesday: Rest or take an easy walk, depending on how you feel and what your schedule allows.
  • Wednesday: Run-walk session. Repeat Monday's workout and see whether you can complete it comfortably.
  • Thursday and Friday: Rest or do light activity such as walking.
  • Saturday: Optional run-walk session. If two sessions a week feel comfortable and you're recovering well between them, consider adding a third. Otherwise, stick with two.
  • Sunday: Rest or take an easy walk, depending on how you feel.
Use this example to establish a routine rather than as a set of workouts you must complete. Find a schedule you can maintain before adding sessions or making them longer.
Match Intensity to Your Goal
Choose your effort based on the goal of each workout, rather than always trying to run easier or push yourself harder. For easy runs that build your aerobic base, start at an effort where you can hold a comfortable conversation and use your personal Zone 2 range as an additional reference. For tempo runs or threshold training, set your intensity according to the specific workout and your personal heart rate zones.
During the run, use your breathing, perceived effort, and heart rate to check whether you’re working at the right intensity. If the effort is clearly higher than the workout calls for, slow down rather than forcing yourself to hold the planned pace. With a compatible Suunto sports watch paired with a heart rate belt, you can also use Suunto ZoneSense intensity feedback to help assess whether your effort matches the goal of the session.
Progress Gradually
Once you can complete your current training consistently and recover well, make small adjustments toward your goals. To run continuously for longer, gradually extend your running intervals or reduce the share of time spent walking. To increase your overall volume, extend one session or adjust how often you run each week.
Change one variable at a time, and watch how you handle the following workouts and how you recover before increasing the load again. Adapting to your current routine is a cue to consolidate before adding more. Lock in your progress first, then build gradually.
How to Monitor Your Endurance Training Progress
You don’t need to run faster or farther every time to tell whether your endurance is improving. Choose a workout you can repeat under similar conditions, then compare your performance over time. Look for changes such as:
  • Spending more time running within the same workout duration: You need fewer walking breaks or stops, allowing you to spend more time running.
  • Taking longer to reach the point where running feels difficult: You can maintain your usual effort for longer than before.
  • Maintaining a steadier effort in the second half of the run: As fatigue sets in, you slow down less, take fewer breaks, or are less likely to cut the workout short.
Consistent changes across multiple sessions, rather than a single good run, can indicate improving endurance. Rather than increasing your training load immediately, maintain your current routine to consolidate progress, then adjust gradually based on your goals and recovery.
If progress stalls, check your training consistency and recovery first. A noticeable drop in pace after extending your runs may mean you started too fast or increased the duration too much. A decline across several sessions calls for a review of your overall training load and recovery time. Seek professional evaluation for persistent pain or significant discomfort.
A Suunto watch and the Suunto app can record workout data, including running time. You can also make a note after each session of when or where you started to feel noticeably fatigued and how often you needed to stop, making it easier to compare your runs later. When reviewing your progress, account for differences in weather, fueling, and training intensity.
Takeaways
Start with a level of training you can complete consistently, then build your routine and make gradual adjustments based on your goals and how your body responds. Track your performance over time to identify progress, and allow enough time for recovery so you can keep training sustainably.
FAQ
Can you build endurance without running?
Absolutely! Walking, cycling, and swimming all build endurance. If your goal is better running, they make good complements, but you'll still need running-specific workouts.
Is HIIT better than endurance training?
It depends on your goals. HIIT is itself a form of endurance training, focused on performance at higher intensities, and you can combine it with other methods to suit your needs.
Can you do endurance training every day?
That depends on the intensity and duration of your workouts and how well you recover. Beginners do well to schedule rest days or non-running days between runs.
Does endurance training build muscle?
Muscular endurance and muscle size are two different goals. Running, cycling, and swimming mainly develop endurance. If you want to build muscle, add strength training with progressively increasing loads.
