Suunto 5 User guide
Adjusting settings
To adjust a setting:
  1. Press the upper right button until you see the settings icon, then press the middle button to enter the settings menu.
    Settings icon
  2. Scroll through the settings menu by pressing the upper right or lower right buttons.
    SF3 Settings
  3. Select a setting by pressing the middle button when the setting is highlighted. Go back in the menu by pressing the lower left button.
  1. For settings with a value range, change the value by pressing the upper right or lower right button.
    Backlight mode
  2. For settings with just on or off, change the value by pressing the middle button.
    Alarm setting
You can also access general settings from the shortcuts menu by keeping the middle button pressed.
InContext menu
Indice
