When a sport mode is selected, keep Next pressed to access additional options to be used during your exercise:
Select Navigation to access the following options:
Select Track back to retrace your route at any point of your exercise.
Select Find back to navigate back to the starting point of your exercise.
Select Location to check the coordinates of your current location, or save it as a POI.
Select POIs (Points of interest) to navigate to a POI.
Select Routes to navigate a route.
Select Logbook to navigate a route of one of your saved logs with GPS data.
Select Activate to set the following features on or off:
Select Interval off/on to activate/deactivate interval timer. The interval timer can be added to custom sport modes in Movescount. For more information, see Using interval timer.
Select Autopause off/on to activate/deactivate autopause.
Select Autoscroll off/on to activate/deactivate autoscroll.
Select HR limits off/on to set the HR limits on or off. The heart rate limit values can be specified in Movescount.
Select Compass off/on to activate/deactivate the compass. When the compass is activated during exercise, it is shown as an additional display after the sport mode.
