Suunto Nautic User Guide
- Time and date
Time and date
You can set time and date during the initial startup of your device. After this, your device uses GPS time to correct any offset. To change these settings, go to Control panel > Device settings > Time/date.
Once you have paired with Suunto app, your device gets updated time, date, time zone and daylight-saving time from mobile devices.
In the Settings, under General » Time/date, select Auto time update to toggle the feature on and off. If you toggle the feature off, you can manually adjust the time and date. You can also change the time and date formats.
