Interval Training for Running: Benefits & Workouts
SuuntoRun — 21 十月 2026
Interval training for running alternates harder efforts with recovery periods to build speed and endurance. Done well, every session is controlled and repeatable, with the format, intensity, and recovery matched to your goals and fitness level. This guide covers how running intervals work, the most common types, how to set intensity, recovery, and frequency, and practical workouts you can follow and adapt to your own plan.
What Is Interval Training and What Are Its Benefits?
Interval training alternates higher-intensity exercise with low-intensity activity or rest. A typical session is built from work intervals, recovery intervals, and a set number of repetitions. The method works across running, cycling, swimming, and other sports, but this guide focuses on running.
Alternating faster running with jogging, walking, or rest gives interval running several potential benefits, depending on how you structure the workout:
  • Better cardiorespiratory endurance: Improves your body’s ability to deliver and use oxygen during exercise, making interval running a useful part of an endurance training plan.
  • Stronger speed endurance: Builds your ability to resist fatigue at faster speeds and hold your pace through the later stages of a run.
  • More explosive power: Short sprint intervals can improve neuromuscular performance, helping you accelerate and sprint more effectively.
cycling with suunto
What Is High-Intensity Interval Training?
High-intensity interval training (HIIT) is a form of interval training where work intervals are run at high or near-maximal effort, separated by recovery periods. All HIIT is interval training, but not all interval training is HIIT. Many running interval sessions use controlled speeds or threshold intensity, well below maximal effort.
What Are the Examples of Interval Running?
You can structure running intervals in several ways, depending on work interval length and training focus. These formats overlap rather than sitting in separate categories. Whichever you choose, the overall training load still comes down to work intensity, recovery, and the number of repetitions.
Time-Based and Distance-Based Intervals
  • Time-Based Intervals: For example, run at a faster pace for 2 minutes, then jog easily for 2 minutes to recover. Each interval can cover a different distance, which makes this format easy to use on any route or terrain and simple to control by time.
  • Distance-Based Intervals: For example, run 400 meters or 1 kilometer, then recover. This format makes it easier to monitor pace consistency across repetitions and works well on a track or when you’re training for a specific race distance.
suunto race 3s with pace and distance
New to interval training, or often running on varied routes and terrain? Time-based intervals are usually easier to follow. If you want to practice a specific pace, compare repetitions, or prepare for a 5K or 10K, distance-based intervals are often more useful.
Short, Long, Pyramid, and Fartlek Intervals
Beyond time and distance, you can also group running intervals by work interval length, workout structure, or how your speed changes through the session.
  • Short and Long Intervals: These differ in how long each work interval lasts. Short intervals use brief efforts and are often used to sharpen speed and pace control. Long intervals use sustained efforts that help you accumulate more time at higher intensity.
  • Pyramid Intervals: Work intervals build in length, then step back down. For example, run faster for 1, 2, 3, 4, 3, 2, and 1 minute, with recovery between each.
  • Fartlek Runs: Mix faster and slower running within one continuous run. Speed changes can follow perceived effort, terrain, or a planned structure, which makes fartlek one of the most flexible formats.
interval running with suunto
How to Do Interval Training
When planning an interval workout, start with four key variables, then adjust based on how you perform:
  • Work Interval: The duration or distance of each faster segment, such as 1 minute, 3 minutes, 200 meters, or 1 kilometer.
  • Intensity: Your target pace, heart rate, or power for each work interval.
  • Recovery Interval: The recovery time or distance between repetitions.
  • Repetitions and Total Workload: How many work intervals you’ll complete, and the total duration or distance of the session.
You can build a structured workout in the Suunto app and sync it to a compatible watch, so you always know whether you’re in a work or recovery interval mid-run.
structured workout in Suunto products
How to Set Interval Intensity
Match your interval intensity to your training goal. Start by judging how hard you’re working, then use your workout data to fine-tune the effort.
  • Perceived effort: Rate how hard you’re working on a 0 to 10 rating of perceived exertion (RPE) scale. For high-intensity intervals, an RPE of 7 to 9 is a useful guide. Set the effort to your training goal rather than sprinting all-out on every repetition.
  • Device data: Use target pace and heart rate to monitor intensity. If you have reliable maximum heart rate or lactate threshold data, you can use it to set your personal heart rate zones. For shorter intervals, lean on pace and RPE, since heart rate can lag behind changes in effort.
Wear a Suunto sports watch to track real-time pace and heart rate during the session. Afterward, compare your data across repetitions to see whether your pace held steady and your heart rate responded as expected.
For deeper insight into real-time exercise intensity, explore Suunto ZoneSense, which uses heart rate variability (HRV) data on compatible Suunto watches to show how your body responds to different training intensities.
training intensity in Suunto ZoneSense
How to Plan Recovery Between Intervals
The right recovery depends on your training goal and how much rest you need to hit your target intensity on the next interval.
  • Choose your recovery method: Jogging keeps you moving at low intensity, while walking or standing still reduces the workload further. Pick the option that best supports your recovery needs.
  • Set your recovery duration: Start with a fixed recovery time, then check whether you can hold your target pace and good form on the next interval. If your pace drops significantly or your effort and form start to slip, extend the recovery. If your goal is to build more time at target intensity, keep breaks only as long as you need. Your heart rate can stay elevated between intervals; it doesn’t need to return to resting before you go again.
How Often Should You Do Interval Training?
If you’re new to interval running, start with one session per week. Once your body adapts, you can build to two. Schedule recovery runs or rest days between interval sessions to keep high-intensity workouts from landing back to back.
If you’re still noticeably fatigued or sore on a planned interval day, move the session. If a second weekly session makes it hard to complete your planned workouts or keeps affecting your easy runs, drop back to one.
Interval Running Workouts by Goal
Once you understand how interval training works and how to structure a session, choose a workout based on your current running fitness and goals. Treat the examples below as starting points, and adjust pace, recovery time, and total workload to your ability. Start every session with an easy run and a dynamic warm-up, and finish with an easy run or walk to cool down.
dynamic warm-up before running
For Beginners: Run-Walk Intervals
If you’re new to running or not yet comfortable running continuously, run-walk intervals are a simple way to build running endurance. Keep the effort manageable and extend your running time as your body adapts.
  • Warm-up: 5 minutes of easy walking
  • Work interval: 1 minute of easy running
  • Recovery interval: 2 minutes of walking
  • Repetitions: 8
  • Cool-down: 5 minutes of easy walking
Keep the running segments easy and controlled, at an effort where you can still talk in short sentences. Focus on consistency over speed. As you adapt, gradually lengthen the running intervals or shorten the walking breaks.
For Intermediate Runners: Short and Long Intervals
If you already run regularly, choose short or long intervals based on the goal of the session. Short intervals build coordination and pace control at faster speeds, while long intervals help you accumulate more time at higher intensity.
  • Warm-up: 10 to 15 minutes of easy running, followed by dynamic warm-up exercises
  • Short interval example: Run 200 meters at a faster pace, then recover with 200 meters of easy jogging or walking. Repeat 6 to 8 times.
  • Long interval example: Run at a higher intensity for 3 minutes, then recover with 2 minutes of easy jogging. Repeat 4 times.
  • Cool-down: 5 to 10 minutes of easy running or walking
Match the intensity to the length of each work interval, and adjust as you go so you can finish the full workout at the right effort.
road running with suunto
For Race Preparation: Race-Pace Intervals
If you have a solid training base and a 5K or 10K on the calendar, race-pace intervals help you lock in your target pace and practice holding it across repeated efforts.
  • Work interval: Run 1 kilometer at your target race pace
  • Recovery interval: 2 to 3 minutes of easy jogging
  • Repetitions: 3 to 5
Trying this workout for the first time? Start with 3 repetitions and add more as your performance and recovery allow. The goal is a steady target pace on every repetition, rather than a faster one each time. If you’re preparing for a half marathon or marathon, adjust the length of each work interval and the total workload to suit your race distance and training phase.
How to Track Your Interval Training Progress
The clearest way to measure progress is to compare workouts completed under similar conditions. Watch for these changes:
  • Pace at the same target intensity: In similar workouts, can you hold your target pace more consistently and avoid major slowdowns in the later repetitions?
  • Heart rate at a similar pace: Under comparable conditions, such as route, weather, and workout intensity, does your heart rate show a consistent trend over time? A single fluctuation isn’t enough to signal improved fitness.
  • Perceived effort during the workout: Does the same workload gradually feel more manageable? Can you recover enough within each planned recovery interval to be ready for the next repetition?
  • Post-workout recovery: Can you keep up your usual performance on the easy runs that follow, without lingering fatigue?
Use the Suunto app to review your training history and compare pace, heart rate, and perceived effort across similar workouts. Your Chronic Training Load (CTL) trend also shows your accumulated training load over recent weeks, so you can judge whether it suits your recovery.
suunto ai coach
For a more personalized training plan, use Suunto AI Coach in the Suunto app with Suunto Race 3S. Based on your training goals, recent performance, and recovery data, it can help you decide whether to adjust today’s interval workout and how to plan the sessions that follow.
Takeaways
Interval training balances work intensity, recovery, and total workload to make speed work controlled and repeatable. Whether you’re building a running habit with run-walk intervals or dialing in your target race pace, prioritize good form and consistent pacing across every repetition over a single all-out effort.
Treat interval training as part of a long-term plan. Start at an intensity and workload that suit your current fitness, adjust frequency based on recovery, and track progress by comparing similar workouts over time. Build the workload when you can complete sessions consistently, and ease back when fatigue builds or performance dips. That’s how you get faster through sustainable training.
FAQ
What Is Interval Strength Training?
Interval strength training alternates strength exercises with rest or low-intensity activity. For example, you might complete a set of squats, take a short break, then move on to the next set.
Can Interval Running Improve Endurance?
Yes. Interval running can improve your aerobic fitness and your ability to sustain a run. Combine it with easy runs and long runs as part of a balanced endurance training plan.
Is 20 Minutes of Interval Training Enough?
Yes. A 20-minute interval workout can still deliver real training benefits. Just keep in mind the difference between total workout time and the actual time spent at high intensity, and match the workload to your fitness level.
Why Is My Heart Rate Still High During Interval Recovery?
After a hard effort, your heart rate takes time to come down. Exercise intensity, recovery length, temperature, and accumulated fatigue all affect how quickly it recovers. That’s normal, and your heart rate doesn’t need to return to its resting level between intervals.
