Suunto Traverse Alpha User Guide - 2.1
Set up
To start using your watch:
- Keep pressed to wake up the device.
- Press or to scroll to the desired language and press to select.
- Follow the startup wizard to complete initial settings. Set values with or and press to accept and go to the next step.
After completing the setup wizard, charge the watch with the supplied USB cable until the battery is fully charged.
If a blinking battery symbol is displayed, Suunto Traverse Alpha needs to be charged before starting.
If the battery dies, and you recharge the product, press and hold START to start the product
