Aerobic vs Anaerobic Exercise: Key Differences and Training
SuuntoRun — 6 October 2026
The key difference between aerobic and anaerobic exercise is how your body supplies energy for movement. From an easy run to a sprint up a steep hill, how hard and how long you exercise changes the contribution of each energy system, and how your body adapts to training. Understanding those differences gives every workout a clear purpose. This guide covers common aerobic and anaerobic activities, how to gauge exercise intensity, and how to combine both types of training for endurance, strength, or speed.
What Is the Difference Between Aerobic and Anaerobic Exercise?
Aerobic and anaerobic exercise differ in their main energy pathways, typical intensity, and duration. Here’s what each involves, along with common examples and a comparison of their key features.
1. What Is Aerobic Exercise?
Aerobic exercise relies primarily on aerobic metabolism, which uses oxygen to produce adenosine triphosphate (ATP), the energy that powers muscle contractions. This pathway supports sustained activity, such as an easy run or a steady bike ride.
Common examples include easy running, steady cycling, continuous swimming, and hiking. At an easy intensity, you should be able to talk comfortably. Build duration gradually to suit your fitness and recovery.
2. What Is Anaerobic Exercise?
Anaerobic exercise relies primarily on the phosphagen system and anaerobic glycolysis to replenish ATP quickly. These energy pathways do not directly require oxygen and support short bursts of intense exercise. “Anaerobic” describes how that energy is supplied; it doesn’t mean you stop breathing or no longer need oxygen.
Common examples include short running or cycling sprints, heavy strength training with low repetitions, and short sets of explosive jumps. Allow enough recovery between repetitions or sets to maintain speed, force, and good technique.
road running
3. Key Differences Between Aerobic and Anaerobic Exercise
The table below summarizes the typical differences in energy supply, intensity, duration, activities, and training benefits.
Feature Aerobic Exercise Anaerobic Exercise
Main energy supply Primarily aerobic metabolism, providing a sustained supply of energy Greater reliance on the phosphagen system and anaerobic glycolysis for rapid energy during short, intense bursts
Typical intensity Low to moderate High to near-maximal
Duration Minutes to hours or longer Seconds to a few minutes per intense bout
Common activities Easy running, steady cycling, continuous swimming, hiking Short sprints, heavy lifting with low repetitions, explosive jumps
Typical training benefits Cardiovascular fitness and endurance Strength, muscle growth, explosive power, or speed endurance
How Do Your Energy Systems Work Together?
The comparison above outlines the typical energy demands of each type of exercise. In practice, aerobic and anaerobic systems work together, with their contributions shifting as you move. During a run, a steady, sustainable pace relies mainly on aerobic metabolism. Accelerating, climbing a hill, or sprinting increases the demand for anaerobic energy. When you slow down, aerobic metabolism continues to fuel movement and support recovery.
Running, cycling, or strength training alone doesn’t tell you which energy system contributes most. That depends on the intensity, duration, how you perform each movement, and how much recovery you allow.
running with suunto
Is Aerobic or Anaerobic Exercise Better for Your Goals?
Both have a place in training. The right emphasis depends on what you want to improve. Long distances call for sustained energy, sprints and jumps demand explosive power, and muscle growth requires targeted strength training. Start with the result you want, then choose the training that develops it. Labeling an activity aerobic or anaerobic only tells part of the story.
1. For Endurance and Cardiovascular Fitness
If you want to run farther, finish a long ride, or stay strong through the second half of a hike, aerobic training builds an essential foundation. Regular aerobic training can increase stroke volume, the amount of blood your heart pumps with each beat, and promote adaptations in muscle capillaries and mitochondria. Together, these changes improve oxygen delivery and use, helping you keep going longer.
Endurance develops through consistent training. Low-intensity exercise lets you build duration and frequency while keeping fatigue manageable. That consistency also prepares you for harder workouts, which is why Zone 2 training plays an important role in an endurance plan.
2. For Improving VO₂max
To improve VO₂max, build on steady aerobic training with targeted high-intensity aerobic intervals. These intervals help you accumulate time exercising near your VO₂max.
High-intensity aerobic intervals place greater demands on your heart’s pumping capacity and your muscles’ ability to use oxygen, providing a focused stimulus to improve VO₂max. Allow enough recovery to maintain the quality of these demanding sessions.
3. For Strength, Muscle Growth, and Power
To build strength, muscle, or explosive power, prioritize resistance training that relies heavily on anaerobic energy during each set. The ACSM position stand on resistance training identifies different training priorities for each goal:
  • Build strength: Heavier loads, a full range of motion, and an appropriate number of sets and weekly sessions help improve maximal strength.
  • Build muscle: Higher weekly training volume supports muscle growth. Eccentric overload training, which emphasizes loading the lowering phase, can also help.
  • Develop power: Moderate loads, low to moderate training volume, and fast movement through the concentric (lifting or pushing) phase help develop explosive power.
Aerobic training can complement this work by improving cardiovascular fitness. Strength, muscle growth, and power still require training that specifically targets those qualities.
training with suunto
4. For Fat Burning and Weight Loss
Both aerobic and anaerobic training can be part of a fat-loss plan. The key is to build exercise habits you can sustain and maintain a calorie deficit (using more energy than you consume over time).
Aerobic exercise increases energy expenditure through sustained activity, while strength training helps preserve strength and lean body mass. The proportion of fat you burn during a workout doesn’t determine how much body fat you lose over time. Choose a training routine you can stick with, supported by adequate nutrition and recovery.
How Do You Combine Aerobic and Anaerobic Training?
Start with your weekly schedule. Combine sustained aerobic exercise with strength training, sprints, or other work that supports your goals, then decide whether to spread those sessions across different days or combine them on the same day. Give each workout a clear purpose and leave enough time to recover.
1. Set Your Training Priority
Work out how much time you can train each week, then schedule your priority workouts first. For endurance, build your week around sustained aerobic training and add intervals, sprints, or strength work as needed. For strength, protect the quality of your lifting sessions and fit aerobic exercise around them. When running, cycling, and strength training fall on the same day, start with the workout that matters most to your current goal and requires you to be fresh.
Be specific about what each session involves and how long it will take. Set a duration or distance for aerobic workouts. For sprints, account for repetitions and recovery intervals. For strength training, plan your exercises, sets, reps, and rest between sets. Include recovery time when fitting workouts into your schedule.
check training priority and plan in suunto widgets
2. Plan Your Training Schedule
You can alternate training types across the week: strength training on Monday, followed by an easy run or ride on Tuesday. If your week includes running intervals, sprints, and heavy lower-body lifting, avoid stacking these demanding sessions on consecutive days. Separate them with easy training, upper-body strength work, or rest days.
You can also combine both types within one workout. After warming up, perform short sprints with full recovery between sets, then cool down with an easy jog. Another option is to follow a strength session with some easy aerobic exercise. If you train twice in one day, leave several hours between sessions where possible. Adjust the second workout’s duration or intensity based on how you feel after the first.
3. Balance Intensity and Recovery
Consider the combined load of both types of training. When adding strength work or sprints, start by shortening some existing workouts or moving sessions to different days. Once you can consistently complete the work and recover well, gradually increase duration, repetitions, or load. If fatigue keeps affecting your technique or ability to finish the next workout, reduce volume, lower intensity, or take a rest day.
If running or cycling is your main focus, the 80/20 principle can help guide your endurance training: keep most of it at low intensity, with a smaller share devoted to harder work. This describes intensity distribution, not “80% aerobic and 20% anaerobic.” Schedule strength training separately while accounting for its contribution to your overall recovery needs.
Compatible Suunto watches and the Suunto app provide insights such as Chronic Training Load (CTL) and heart rate variability (HRV) trends. Read these alongside your performance, sleep, and perceived fatigue to assess how well your schedule is working and adjust future training volume and intensity.
Balance Intensity and Recovery with suunto
How Can Intensity Be Monitored in Aerobic and Anaerobic Training?
Once your training is planned, use heart rate, breathing, and perceived effort to check whether you’re exercising at the intended intensity. During sustained runs or rides, these cues help you keep your effort on track. For short sprints or strength work, also pay attention to speed, weight, repetitions, and technique.
A Suunto sports watch lets you check your current heart rate zone. Depending on the model, zones can be set using your maximum heart rate, heart rate reserve, or lactate threshold heart rate. See the heart rate zone guide for details. Without looking at your watch, comfortable conversation is a useful sign of an easy effort. Needing a breath after just a few words points to a higher intensity. You can also rate your perceived effort on a scale of 0–10: the CDC describes moderate intensity as about 5–6 and vigorous intensity as about 7–8.
heart rate zones in suunto app
These methods tell you how hard you’re working. A high heart rate or heavy breathing doesn’t automatically mean you’re training anaerobically, and a short sprint may end before your heart rate has time to rise fully. Always interpret those cues in the context of the workout.
Takeaways
Aerobic and anaerobic training both belong in a training plan. The energy systems work together, with their contributions changing as intensity and duration shift. Sustained aerobic training builds an endurance base, while intervals, sprints, and strength work provide targeted challenges to develop speed, power, and strength. Start with your goal, then use heart rate, pace, how you feel, workout quality, and recovery trends to adjust your plan. Your own judgment matters more here than any fixed training ratio.
FAQ
Is a 5K Run Aerobic or Anaerobic?
A 5K is primarily an aerobic endurance event. The exact balance of aerobic and anaerobic energy depends on your pace, changes in pace, finish time, and fitness. Accelerations and sprints increase anaerobic demand at those moments, so no single energy split applies to every 5K.
Is It Better to Run Aerobically or Anaerobically?
Aerobic running should form the foundation of your regular endurance training. Add anaerobic work if you want to improve sprint speed and explosive power. Adjust the balance to your running goals and how well you recover.
Is VO₂max Aerobic or Anaerobic?
VO₂max is an aerobic fitness measure that reflects your maximum capacity to take in and use oxygen. Improving it means developing your aerobic capacity. Both sustained aerobic training and high-intensity aerobic intervals can help.
Can You Do Aerobic and Anaerobic Training on the Same Day?
Yes. Plan the order around your main goal and allow for recovery between sessions. If strength is your priority, you can lift first. If endurance performance matters most, make sure you’re fresh enough to complete your planned run or ride well.
