Suunto equips you for your outdoor adventures – discover new trails, stay confident in the wilderness and train for longer explorations. Your watch is your companion for navigation, staying safe, and monitoring your performance and environment in your outdoor sports.
Adventure starts here.
Black
Ultra-endurance GPS watch with exceptional battery life and barometer
Compare Suunto 9 Baro, Suunto 7 and Suunto 5 to learn what are their differences and which model is best for you.
Follow context-based weather insights and warnings during your outdoor activity with your Suunto 9 Baro. Keep alert with storm alarms, measure water temperature or notice if your hike is going past the sunset.
With Suunto 7, you can easily check the current weather by asking Google or swiping to your Forecast Tile.
Available under SuuntoPlus™ for Suunto 9 Baro and from Wear OS by Google™ for Suunto 7.
Keep track of your effort while hiking up a mountain, rock climbing, doing hill repeats in your backyard or running up stairs. Climbs can be viewed afterwards in the Suunto app.
Available under SuuntoPlus™ for Suunto 9 Baro, Suunto 9 and Suunto 5.
Quick access to your GPS coordinates and other key information of your current location as well as your starting point. Useful when sharing your location with a friend, when you need to radio for help or navigating back to your car.
Automatic location-based lap insights help you analyze the stats for each loop. Excellent feature when running on a track or cross-country skiing the same loop. Loops can be viewed afterwards in the Suunto app.
Track sprints automatically while running or cycling to see the number, distance, and time of each interval during your training session. Sprints are identified based on the changes of your running pace or cycling power. Sprints can be viewed afterwards in the Suunto app.
Getting ready for the race? The Wings for Life World Run feature simulates the Catcher Car to motivate your daily workouts and help you train for the race.
Navigate on the go. Choose your target direction, get the bearing and off you go! You can also define your target distance and altitude. Great orienteering tool for mountains and forests.
Available for Suunto 9 Baro and Suunto 9.
See key insights of your surroundings while getting ready for your adventures. The design is inspired by Suunto’s heritage with marine compasses.
Available for Suunto 9 Baro, Suunto 9, Suunto 5 and Suunto 3.
Create your own route, use tracks from other services or select a popular trail in the Suunto app. Sync the route to your watch and off you go! With route navigation on your watch you'll always find your way.
Route navigation is available for Suunto 9 Baro, Suunto 9, Suunto 7 and Suunto 5. Outdoor maps are visible on the watch only for Suunto 7.
Your display stays awake all the time while you exercise, using only a minimum amount of battery. This enables you to constantly see all your training data without having to raise your wrist to activate the display.
All Suunto products have the screen on while exercising. Now this feature is also available for Suunto 7.
Selecting 'Good' location accuracy makes the battery last longer during your outdoor workouts. Prepare for longer sessions or use it when you are already low on battery and want to keep going. When running or cycling, FusedTrack™ is used to improve tracking quality.*
Product-specific battery-saving options are available for Suunto 9 Baro, Suunto 9, Suunto 7 and Suunto 5.
Quickly see what weather is coming your way with MyRadar. This app gives you real-time weather with local animated weather maps so you can plan your outdoor adventures. Read more about MyRadar.
Available for Suunto 7.
When heading to a new place or route, it’s often hard to figure out where to start. Check out popular starting points in the Suunto app to easily know where to start your adventure from.
Available on the Suunto app. The popular starting points are also visible with heatmaps on Suunto 7.
Getting bored of running the same trails but not sure where to go? We made finding new routes easy for you by adding popular routes to the Suunto app. These routes are generated from the exercises of the Suunto community.
See your own personal heatmap with a daily, monthly, and current year view. You can also compare your tracks with the most popular routes for your sport.
Improved Suunto app home page will give you direct access to your calendar, activity totals and map.
Find your next trip from Sportihome, check the best routes with Wikiloc or view your tracks with Land. Suunto partners give you tools for your next trail run or mountain trip.
Learn more from suunto.com/partners.
Hill repeats are an essential part of an outdoor athlete’s workout repertoire. To make the hard work pay off, pacing is the key.
Whether you want to start from scratch, use an existing route or something in between, here are six different ways to create a route for your Suunto watch.
The Suunto 7’s navigation aids make finding your way a breeze.
Study our series on mountain navigation and gain the confidence you need to find your way.
* The estimated figures are valid only when using Suunto Wear app. Actual battery life may vary considerably depending on sports, settings, applications, and many other factors e.g. if you're measuring sleep.
Google, Android, Google Play, Wear OS by Google, Google Pay and Google Fit are trademarks of Google LLC. Availability of Google Assistant and Google Pay varies by language, country and bank partner.
Learn more about Google Assistant Learn more about Google Pay
Wear OS by Google works with phones running the latest version of Android (excluding Go edition and phones without Google Play Store) or iOS. Supported features may vary between platforms and countries with compatibility subject to change.
