NEW: WE NOW SHIP TO HONG-KONG SAR CHINA | FREE SHIPPING OVER $1800 | EASY RETURNS | SIGN UP FOR NEWSLETTER
How to get more accurate GPS tracking?
Find useful tips and troubleshooting steps for better GPS tracking.
To learn more about the basics of how GPS watches measure altitude, altitude changes and the difference between GPS and barometer watches, read this article.
Tips:
1. Always wait for GPS signal before starting an exercise
Before starting an exercise using GPS, wait for the watch to find the GPS signal indicated by the blinking grey arrow that will turn colored (green or color of the battery mode you use) once GPS signal has been found. Ideally wait some additional minutes to allow the watch to download all needed GPS data, especially for open water swimming or when exercising in difficult terrain. Only then start the exercise.
2. Use the latest software for your watch
We continuously improve the software of our watches and fix possible bugs. Ensure you have the latest software installed on your watch. Get the latest software.
Learn how to update your watch with this video.
3. Connect your watch to Suunto app
Suunto app updates the GPS data file in your watch. Sync your watch with Suunto app ideally before every exercise using GPS to get the latest GPS information.
To verify when the GPS data file on your watch was last updated, open Settings > General > About and scroll to Assisted GPS. Here you will see a time stamp. If the date is older than one day or if you see N/A, please synchronize your watch with Suunto app. Verify after syncing if the GPS data file was updated by checking the date under Assisted GPS.
Download Suunto app from the App Store or Play Store and learn here how to pair with iOS and Android. Remember to update your Suunto app when there is a new version available.
4. Suunto Spartan: Use GPS accuracy Best
The GPS accuracy determines at what rate your watch gets a GPS position fix. The higher the fix rate (the shorter the interval between the fixes), the more accurate your track.
For Spartans the GPS accuracy can be set for each sport mode individually in the Options menu below the exercise start screen.
5. Suunto 9 and Suunto 5: Use battery mode Performance
Record your exercise with the default battery mode Performance which uses GPS accuracy Best or create a custom battery mode which uses GPS accuracy Best. Battery modes Endurance (Suunto 9 and Suunto 5) and Ultra (Suunto 9 only) use lower GPS fix rates.
6. Training in difficult terrain
The GPS signal strength is influenced by various factors and can
  • trees
  • water
  • buildings
  • bridges
  • metal constructions
  • mountains
  • in gullies or ravines
  • thick, humid clouds
To get better GPS tracking results when exercising in difficult terrains like e.g. in a dense forest, ravine or city with tall buildings, it may help to turn on additional satellite navigation systems such as GLONASS or Galileo if available in your watch.
Spartans: Open the sport mode you will be exercising with, scroll down to the Options menu, toggle on GLONASS. On Spartans it is possible to activate an additional navigation system during an active exercise. Simply long press the middle button to open the Options menu, scroll to GLONASS and toggle it on.
Suunto 9: Open Settings > Navigation > GPS system. Select GPS+GLONASS or GPS+Galileo (coming in a software update in summer 2019).
Suunto 5: Open Settings > Navigation > GPS system. Select GPS+GLONASS or GPS+Galileo.
7. Open water swimming
We covered this topic in a separate article.
Troubleshooting steps:
If your watch provides incorrect GPS tracks or does not get a GPS fix:
  1. Soft reset your watch. Learn more.
  2. Connect you watch with Suunto app and synchronize it.
  3. Verify on your watch that the GPS data file has be successfully updated. Open Settings > General > About and scroll to Assisted GPS. Here you should see today’s time stamp. If this is not the case or you see N/A, please synchronize your watch again with Suunto app. Repeat this until the time stamp shows today’s date.
If a saved POI does not show GPS coordinates, or your watch does not find your location:
If you have set a country specific position format e.g. British (BNG), Finnish (KKJ) or other, you travel outside of this country and face the described issues, switch to an international position format e.g. WGS84 Hd.d°, UTM or MGRS. To switch, open Settings > Navigation > Position format.
RELATED ARTICLES
