Steady State Cardio: Benefits and How to Do It
SuuntoRun — 27 november 2026
Head out for an easy run, bike ride or brisk walk, and once you find your rhythm, it feels like you could keep going for hours. Your breathing stays smooth, you're nowhere near gasping, and holding the pace takes no gritted teeth. Endurance training has a name for that sustainable, low-to-moderate continuous effort: steady state cardio.
Whether you want to build an aerobic base, add active recovery or simply make movement a regular part of your week, steady state cardio is one of the most approachable ways to train. This guide covers what it is, what it does for your fitness, how to set your intensity and weekly volume, and which workouts suit it best.
What Is Steady State Cardio?
Steady state cardio is continuous aerobic training at a low-to-moderate intensity, held for an extended period.
"Steady state" describes what happens inside your body a few minutes into a consistent, comfortable effort: your heart rate, breathing and energy metabolism level off, and the oxygen your muscles need matches the oxygen you're supplying. Push the intensity too high and that balance starts to break down.
You'll often hear steady state cardio used alongside terms like Moderate-Intensity Continuous Training (MICT) and Low-Intensity Steady State (LISS). For everyday athletes, it all comes down to the same thing: a low-to-moderate effort with a steady rhythm and controlled breathing that you can hold for a long time.
What Are the Benefits of Steady State Cardio?
The benefits of steady state cardio build up through consistent weekly volume rather than any single workout. The biggest payoffs show up in your performance and day-to-day recovery:
  • Builds your aerobic base: Regular steady sessions help your heart deliver oxygen more efficiently and train your muscles to use it better. On a long run or ride, that means holding your rhythm for longer before you start to fade.
  • Recovers quickly, so it fits around harder sessions: Heart rate variability (HRV) bounces back quickly after lower-intensity steady work. Because a single session leaves little lasting fatigue, you can build weekly volume while keeping your legs fresh for harder, high-quality workouts.
  • Supports long-term heart and metabolic health: Consistent endurance training helps lower your resting heart rate, improve resting blood pressure and increase whole-body insulin sensitivity through muscular adaptations, giving you a stronger foundation for ongoing training.
  • Lifts your mood and makes consistency easier: Both individual sessions and a regular aerobic routine can boost positive mood, ease negative emotions and take the edge off stress, which makes it easier to stick with training over the long run.
Steady State Cardio vs. HIIT: Key Differences
When planning endurance training, steady state cardio is often compared with high-intensity interval training (HIIT). In practice, you can use both.
For fat loss, the two deliver very similar results over the medium to long term. Over comparable training periods with similar overall commitment, HIIT and steady state cardio reduce total body fat by about the same amount. The real differences come down to three things:
  • Time efficiency: HIIT's main advantage is saving time. It reaches similar results with less total training time, while steady state sessions run longer and take a bigger block out of your schedule.
  • Aerobic ceiling: HIIT has a slight edge for raising peak oxygen uptake (VO2peak), the most oxygen your body can take in and use at maximal effort. The higher that ceiling, the better you cope with heavy breathing and hard efforts at a fast pace.
  • Post-workout recovery: HIIT noticeably slows post-exercise HRV recovery, so fatigue tends to linger. Low-to-moderate steady state cardio lets your body bounce back faster, which makes it better suited to carrying most of your weekly aerobic volume. If your goal is building an endurance base or recovering between hard days, steady state cardio is the more reliable foundation. If your schedule is tight, or you already have a solid base and want to raise your top-end fitness, adding some HIIT makes sense.
How Long and How Often Should You Do Steady State Cardio?
For most healthy adults, either 150 to 300 minutes of moderate aerobic activity a week or roughly 3 to 5 sessions of 30 to 60 minutes per week is a practical, sustainable place to start. From there, adjust based on your fitness, recovery and goals. What matters most is a frequency that fits your schedule and that your body can keep up with week after week.
Keep these guidelines in mind as you plan your week:
  • Split your time when you need to: If you can't fit a full 30- to 60-minute session in one go, building the same weekly total from shorter sessions still delivers similar cardiovascular benefits.
  • Extend single sessions for longer goals: Training for a half marathon, marathon or other long-distance event? Gradually lengthen one or two of your weekly steady state sessions to build durability for the late stages of a race. Across the week, keeping most of your endurance time easy, with a smaller share of hard work, is a balanced way to build volume.
  • Match frequency to your fitness and training load: If you're just starting out or already doing a lot of high-intensity work, begin with 2 to 3 steady state sessions a week. Once your fitness and recovery settle, build toward 4 to 5.
How Do You Gauge Steady State Cardio Intensity?
To get the most from steady state cardio, keep each session in the right intensity range. Because different sports work your muscles differently and come with different resistance, the most practical approach is to combine heart rate zones with perceived effort.
Using Heart Rate Zones
For steady state cardio, Zones 1 to 3 of the five-zone model are your go-to heart rate zones, covering everything from easy recovery work to standard aerobic training. With a Suunto watch that supports heart rate zones, you can choose your target zone before you start and get an alert whenever your intensity drifts out of range. Because pace shifts with hills, wind and daily fatigue, heart rate zones are often a more dependable guide for holding a steady effort. Keep in mind that during long sessions at a steady pace, you may notice cardiac drift: your heart rate gradually climbs even though your pace or power stays the same. If your heart rate creeps up slightly in the second half of a workout, check your breathing and how you feel alongside the numbers before concluding you're working too hard.
Using the Talk Test and Perceived Exertion
Heat, poor sleep and accumulated fatigue can all push your heart rate away from its usual baseline, so heart rate data works best alongside the Talk Test and Rate of Perceived Exertion (RPE).
Aim for the highest effort at which you can still speak comfortably in full sentences, or around 12 to 13 on the standard 6 to 20 RPE scale. On that scale, higher numbers mean harder work, and 12 to 13 feels somewhat challenging yet sustainable. At that level, your heart rate and metabolic load usually sit firmly in steady state territory. Once you can no longer finish a sentence smoothly, take it as a cue that you're working too hard and ease back.
Combining heart rate zones and perceived effort, use the table below to choose and fine-tune your target zone based on your goal and how you feel on the day:
Metric Recovery (Zone 1) Low-Intensity (Zone 2) Moderate (Zone 3)
Five-Zone Heart Rate Model Approx. 50%–60% HRmax Approx. 60%–70% HRmax Approx. 70%–80% HRmax
RPE Very easy; almost no breathing strain Easy and controlled; sustainable for long stretches Somewhat challenging, yet still controlled
Talk Test Smooth breathing; easy to speak in long, full sentences Comfortable speaking in connected, full sentences Can speak in full sentences, with occasional pauses to breathe
Best For Lightest load with minimal added fatigue; fits warm-ups, cool-downs, active recovery days after hard sessions, or early base building Go-to aerobic base zone balancing endurance gains with quick recovery; works well for weekly long sessions and everyday volume Higher cardiovascular and breathing load; fits athletes with an existing base who are short on time or aiming for a slightly brisker steady effort
Steady State Cardio Examples for Your Routine
Once you know how to gauge intensity with heart rate and feel, steady state cardio carries over into plenty of everyday activities—not just one sport. Based on the impact your joints and muscles absorb, common options split into low-impact and high-impact choices you can mix and match around your joint health, background, and weekly schedule.
Low-Impact Options: Walking, Cycling, Rowing, and Swimming
Brisk walking, incline walking, indoor or road cycling, rowing, and swimming are all classic low-impact aerobic choices. Without the repeated landing impact of running, they fit anyone looking to cut down lower-body stress, build an aerobic base, or slot in active recovery between harder days. Keep in mind that heart rate responds differently across sports at the same perceived effort. Rather than copying your running heart rate zones straight over to cycling or swimming, pair your numbers with how your breathing and effort feel.
High-Impact Options: Running
Running comes with landing impact, making it a better fit if you already have some conditioning under your belt or want a simple way to train outdoors or on a treadmill. Compared with walking or cycling, heart rate can run a bit higher at the same perceived effort.
Everyday steady state running usually takes two forms: an even-paced easy run on flat roads or a treadmill, or a run-walk approach—such as jogging for a few minutes followed by a short walk break—during long sessions, summer heat, or recovery phases to keep heart rate steady. Because running puts more cumulative load on the lower body, build mileage gradually and leave room to recover.
Conclusion
The real value of steady state cardio is giving you a pace your body can absorb and recover from, so endurance training fits into your week for the long haul. You don't need to chase faster splits or empty the tank every time you head out. Use heart rate zones and the Talk Test to stay inside that steady, sustainable boundary, and your aerobic base and overall fitness will build quietly over time.
FAQs
Is 30 minutes of steady state cardio enough to see results?
Yes. Five 30-minute sessions a week add up to the 150-minute weekly aerobic benchmark, which is enough to drive clear gains in cardiorespiratory fitness and cardiometabolic health. Showing up consistently matters far more than grinding through the occasional long session.
Should you do steady state cardio before or after strength training?
It depends on what matters most that day. If strength training is your main session, lift first and do steady state cardio afterward. If a long aerobic workout is the priority, lead with cardio. When neither takes priority, lifting first and doing cardio second is still the safer call. If your schedule allows splitting them into two sessions on the same day, aim for at least 6 hours between strength work and running.
What is the difference between steady state cardio and Zone 2 training?
The two overlap a lot in daily training, but they aren't the exact same thing. Zone 2 training specifically refers to roughly 60%–70% HRmax in the five-zone heart rate model. Steady state cardio is the broader umbrella—it includes Zone 2, along with lighter recovery work (Zone 1) and slightly brisker moderate steady efforts (Zone 3) depending on your fitness level and goals.
