How to Prevent Running Injuries: 5 Practical Tips for Runners
SuuntoRun — 25 Novimber 2026
Your training has gone to plan for weeks, and your fitness and pace are heading in the right direction. Then, a few hundred meters into an easy run, a tight, dull ache appears on the outside of your knee. Now the real question hits: "Can I finish today's run as planned, or will pushing through turn a minor twinge into weeks off?"
Most regular runners face this moment sooner or later. Running injuries rarely come out of nowhere. Far more often, your training load has climbed faster than your body can currently handle. Keeping injury risk in check comes down to spotting the early warning signs, sticking to evidence-backed habits and adjusting before a small issue sidelines you for weeks.
Common Running Injuries and Early Warning Signs
Acute injuries like a rolled ankle do happen, but most running injuries are overuse injuries. They build gradually when the repeated impact of landing puts more stress on a muscle, tendon or bone than it can currently tolerate.
General muscle soreness feels broad and spread out. Overuse injuries, by contrast, tend to settle in one specific spot and flare up during the same movements or at the same times of day. The table below maps the pain location and early warning signs of common running injuries, so you can catch them before they get worse:
Common Injury Primary Pain Location Typical Early Signs and Timing
Patellofemoral Pain Syndrome (Runner's Knee) Around or behind the kneecap A dull ache that often worsens going downstairs, squatting, or standing up after sitting for a while
Medial Tibial Stress Syndrome (Shin Splints) Along the inner edge of the shinbone Tightness or tenderness at the start of a run that may ease once you warm up, then return afterward
Achilles Tendinopathy Along the Achilles tendon above the heel Local stiffness or pain, usually most noticeable on your first steps out of bed in the morning
Plantar Fasciitis Under the heel or along the inner arch Sharp pain, classically worst on your first steps in the morning or when standing up after sitting
Iliotibial Band Syndrome (IT Band Syndrome) Outside of the knee Sharp or burning pain that builds after a set distance or on downhill stretches
Bone Stress Injury Deep in a specific spot on the bone Pinpoint bone pain that worsens with every footstrike and, in more severe cases, aches while walking or at rest
Spotting warning signs early lets you pull back before things escalate, but lowering your odds of getting hurt in the first place starts with your daily training habits. Here are five practical injury-prevention steps backed by sports science.
1. Manage Your Running Mileage and Training Load
Of all injury-prevention habits, managing how much you train and how quickly you build it usually matters most.
Avoid Sudden Increases in Running Mileage
Managing your training load starts with avoiding sudden jumps in volume. Every run puts mechanical stress on your musculoskeletal system, and when a single run or a block of training asks more of your tendons, bones or joints than they can handle right now, an overuse injury can follow.
A sharp spike in weekly mileage can noticeably raise your injury risk over the following few weeks. A previous injury is another major risk factor, so after recovering from one, build back even more gradually.
Use the 10% Rule as a Guide
Keeping weekly mileage increases to around 10% is a popular, easy-to-follow guideline that stops most newer runners from ramping up too fast. Treat it as a rough baseline rather than a hard ceiling.
Alongside weekly mileage, keep an eye on intensity, elevation gain and how well you're actually recovering. If you add 10% to your mileage this week, keep those runs flat and easy rather than stacking hard intervals or steep hills on top. And if you've been short on sleep or your legs feel heavy day after day, hold your mileage steady or take a cutback week before building again.
2. Add Strength Training to Prevent Running Injuries
Alongside managing your training load, strength training builds muscle strength, tendon resilience and joint control, helping your body absorb the repeated impact of running. One meta-analysis of randomized controlled trials linked strength training to roughly a 68% reduction in sports injury risk.
Those studies cover a wide range of sports rather than distance running alone, and research focused specifically on runners is still fairly limited. Strength work can't make up for poor mileage planning, but done regularly alongside your running, it goes a long way toward building lower-body support and durability.
Aim for 2 to 3 sessions a week on top of your runs. Prioritize lower-body compound and single-leg exercises that match the stability and impact demands of running, such as squats, single-leg squats, single-leg deadlifts, eccentric calf raises, and core and trunk stability work.
3. Improve Your Running Form When Needed
Once your mileage and strength base are solid, recurring stress in the same spot is a good reason to look more closely at your running form. Changing your form can shift load around your lower body, so it works best as a targeted adjustment rather than a complete overhaul.
Increase Your Running Cadence Gradually
When fine-tuning your running form, cadence is one of the simplest and most practical places to start. Some runners overstride, landing with their foot too far in front of their center of mass. That creates extra braking force and adds impact load to the knees and hips.
If you overstride or keep getting shin or front-of-knee discomfort, try raising your cadence by about 5% with professional guidance and see how your stride and symptoms respond. A slightly quicker cadence shortens your stride, lowers vertical loading rates and reduces mechanical stress on the shins, knees and hips. Bear in mind that lower loading rates are a biomechanical change and don't automatically mean fewer injuries.
On easy runs or during form drills, turn on real-time cadence on your Suunto watch to help you settle into the new rhythm. After training runs or races, compare your average cadence, vertical oscillation and ground contact time across runs in similar conditions (route, shoes and pace) to see whether your mechanics are stabilizing.
Change Your Foot Strike Only When Necessary
Foot strike is another hot topic among runners. If you're running pain-free, there's no strong evidence for forcing a change to your natural strike. A healthy heel striker who suddenly switches to forefoot running can shift load the knees used to share straight onto calves and Achilles tendons that aren't ready for it.
Only change your foot strike when a specific area keeps hurting, and only after an assessment by a physical therapist or qualified coach. For runners with recurring front-of-knee pain, moving from a heel strike to a midfoot or forefoot strike under professional guidance may help take load and pain off the knee.
4. Prioritize Recovery and Include Cross-Training
Running provides the training stimulus, but most tissue repair and adaptation happens between runs. Once your mileage and mechanics are in a good place, protecting the quality of your recovery and spreading out repetitive lower-body impact keeps any one area from getting overloaded.
Get Enough Sleep and Schedule Rest Days
Of everything that goes into recovery, sleep and rest days are non-negotiable. Poor sleep slows your recovery, turning a training load you normally handle into accumulating fatigue. Consistently poor or short sleep is linked to a higher risk of running-related musculoskeletal injuries, and heavier muscle soreness and fatigue often creep in 1 to 2 weeks before an injury appears.
During high-mileage or high-intensity blocks, protect your sleep and build 1 to 2 full rest days or very low-intensity active recovery into each week, so your muscles, tendons and bones have time to rebuild.
Use Low-Impact Cross-Training to Reduce Impact
Beyond full rest days, cross-training is a practical way to cut down on repetitive impact. Mixing other sports into your running week is linked to a lower risk of running injuries.
Cross-training means adding activities like cycling, swimming or the elliptical alongside your runs. Swapping 1 to 2 easy runs a week for a low-impact session keeps your aerobic engine working while giving your legs a break from the pavement.
5. Know When to Rest, Modify Your Run, or See a Doctor
Even with smart pacing, strength work and solid recovery, aches will still crop up over months of running. Telling normal soreness from an early injury warning often decides whether a minor issue clears up on its own or turns into a long layoff.
Tell Normal Muscle Soreness Apart From Running Pain
When stiffness or a dull ache appears after a run, start by working out whether it's normal training soreness or an early warning sign. Normal soreness after a hard or long run usually feels like a broad, dull ache and stiffness across large muscle groups in both legs. It peaks 24 to 72 hours later and fades over the next few days. Pain that zeroes in on one fixed spot, or keeps flaring at the same point in your stride, may point to an underlying injury. A simple 0 to 10 Numeric Rating Scale (NRS, where higher numbers mean stronger pain) can help you gauge where you stand, though it only measures intensity, so deciding whether to keep running still means looking at the full picture.
As a rule of thumb, if local discomfort stays mild (no higher than 5 out of 10 on the NRS), leaves your stride unchanged, holds steady or eases during the run, and is back to baseline by the next morning, you can scale back your mileage, pause hard workouts or switch to low-impact cross-training and easy recovery runs while you monitor how it responds.
Watch for Warning Signs That Mean You Should Stop Running
Mild discomfort often settles when you back off and monitor it, but some symptoms aren't worth testing on a run. Stop running right away and see a sports medicine doctor or orthopedist if you notice any of these red flags for bone stress injuries, nerve compression or structural damage:
  • Localized bone pain: Pain concentrated on one small spot of bone that worsens with every footstrike and is noticeable even during everyday walking.
  • Pain at rest or at night: Local pain that lingers when you're not running, during normal walking or even while resting at night.
  • Joint swelling or catching: Visible swelling around a joint, a catching sensation as it moves, or a feeling that it might give way under your weight.
  • Nerve symptoms: Numbness, tingling or pins and needles in your leg or foot, or pain radiating down your leg.
  • Limping or gait changes: Pain that makes you limp or change how you land to avoid it.
Conclusion
Preventing running injuries comes down to consistent habits rather than one magic fix or piece of gear. Build your training load at a pace your body can adapt to, back it up with regular strength work, good sleep and variety in how you load your legs, and respond early when pain shows up.
FAQs
Does stretching before or after a run prevent injuries?
Stretching on its own hasn't been shown to directly lower running injury rates, but warm-ups and post-run stretching still have their place. A dynamic warm-up raises muscle temperature and eases your heart, lungs and joints into the effort, while light stretching afterward can relieve post-run tightness.
Does running on softer surfaces prevent injuries?
Not necessarily. Mixing in runs on a track or dirt paths can take some load off your lower-body joints compared with running only on concrete or other hard surfaces, but it doesn't guarantee a lower injury risk. And if chasing softer ground puts you on uneven or rolling terrain all the time, your injury risk can actually rise.
Do you need special shoes matched to your arch or foot type to prevent injuries?
There's no reliable evidence that choosing shoes by arch height or pronation type lowers running injury rates. Prioritize fit and comfort when trying shoes on, and replace them once the midsole and outsole show clear wear. If you run higher weekly mileage, rotating between a few comfortable pairs may help spread repetitive stress, since each shoe loads your stride slightly differently.
