Suunto 9 Peak User Guide
Watch faces
Suunto 9 Peak comes with several watch faces to choose from, both digital and analog styles.
To change the watch face:
  1. From your current watch face view, keep the middle button pressed to open the shortcuts menu.
  2. Scroll to Watch face and tap or press the middle button to enter.
watchface-setting
  1. Swipe up and down to scroll through the watch face previews and tap on the one you want to use.
  2. Swipe up and down to scroll through the color options and tap on the one you want to use.
watchface color
Each watch face has additional information, such as date or dual time. Tap the display to switch between views.
Moon phases
In addition to sunrise and sunset times, your watch can track moon phases. The moon phase is based on date you have set in your watch.
The moon phase is available as a view in the outdoor style watch face. Tap on the screen to change the lower row until you see the moon icon and percentage.
Moonphase watchface Spartan
The phases are presented as an icon with percentage as follows:
Moonphase icons Spartan
