45-DAY FREE RETURNS | SUUNTO CHRISTMAS GIFT GUIDE | ORDER FOR CHRISTMAS UNTIL DECEMBER 15TH
Suunto Smart Heart Rate Belt User Guide
Using Suunto Smart Heart Rate Belt
You can use your Suunto Smart Heart Rate Belt to record your heart rate and get accurate calorie consumption information from a wide range of activities, from intense exercising to a stroll in the park.
To use your Suunto Smart Heart Rate Belt:
  1. Put on your Suunto Smart Heart Rate Belt (see Putting on belt).
  2. Start your recording in the paired sports watch or other Bluetooth® Smart enabled device. (see Pairing).
  3. Complete your activity and then stop the recording.
  4. Take off and rinse your heart rate belt or other Movesense garment (see Handling guidelines).
Dry skin under the belt electrodes, a loose or worn out chest strap, and synthetic shirt materials can cause abnormally high heart rate readings. Moisten the belt electrodes well and tighten the belt to avoid heart rate peaks. If you are otherwise concerned about your heart rate, please consult a doctor.
Memory function
You can record your heart rate data when swimming, doing team sports or in any activity where the use of a watch or smartphone is not convenient.
To use Suunto Smart Heart Rate Belt memory function:
  2. Start your activity recording in your Suunto 3, 5, 9, Ambit3 or Traverse sports watch.
  3. Ensure that your heart rate is being recorded, then leave the watch or mobile device behind (for example, in a locker).
  4. Complete your activity as normal, wearing the Suunto Smart Heart Rate Belt the whole time.
  5. Go back to your watch and stop the recording before you take off your Suunto Smart Heart Rate Belt.
  6. Take off and rinse your Suunto Smart Heart Rate Belt or other Movesense garment (see Handling guidelines) after stopping the exercise recording.
The memory function is also used to buffer data whenever the heart rate signal from Suunto Smart Heart Rate Belt to your Suunto sports watch is temporarily lost. Missing data is transferred as soon as the connection is restored.
Using the memory function consumes more battery power in the Suunto Smart Heart Rate Belt compared to normal use with a compatible sports watch.
The memory function is only available when the belt is used with one of the following Suunto sports watch families; Suunto 3, 5, 9, Ambit3 and Traverse.
