FREE SHIPPING OVER R3,000 | SIGN UP FOR NEWSLETTER | NEW LOWER PRICES
Suunto Kailash User Guide - 2.0
Suunto 7R App
Pair your Suunto Kailash with the Suunto 7R App to get notifications on your watch, customize watch settings, as well as share your adventures.
Pairing with Suunto 7R App
If you have not paired your watch with the Suunto 7R App, the watch prompts you are to pair the first time you enter the CONNECTIVITY settings.
To pair the watch and app:
  1. Download and install the Suunto 7R App on your compatible Apple device from the iTunes App Store.
  2. Start the app and turn on Bluetooth if it is not on already. Leave the app running in the foreground on your mobile device.
  3. On your watch, keep the middle button pressed to enter the options menu.
  4. Scroll to CONNECTIVITY with the lower button and select with the middle button.
  5. Select Yes to the Pair MobileApp? question.
  6. Enter the passkey shown on your watch display into the paring request field on your mobile device and tap Pair.
Bluetooth
Bluetooth is on by default in Suunto Kailash. It activates automatically to send and receive information with your mobile device when you have paired your watch with the Suunto 7R App.
However, if you are not using the app, or do not want to have Bluetooth on, you can turn it off. Note that the Bluetooth setting is visible only if your phone and watch are already paired.
To turn Bluetooth on/off:
  1. Keep the middle button pressed to enter the options menu.
  2. Scroll to CONNECTIVITY with the lower button and select with the middle button.
  3. Scroll to Bluetooth with the lower button and select with the middle button.
  4. Turn on/off with the 7R or lower button and confirm with the middle button.
  5. Keep the middle button pressed to exit.
Notifications
If you have paired your Suunto Kailash with the Suunto 7R App, you can get call, message and push notifications on the watch.
notifications Kailash
Notifications automatically disappear once you have viewed them on your smartphone.
To turn notifications on/off:
  3. Scroll to Notifications with the lower button and select with the middle button.
  4. Toggle on or off with the 7R or lower button and confirm with the middle button.
