Recovery Runs: How and When to Do Them
SuuntoRun — 12 octobre 2026
Yesterday's workout was tough, and your legs still feel heavy. Should you head out for an easy run or take the day off? Knowing what a recovery run is for, and how to approach one, makes that call much easier.
What Is a Recovery Run?
A recovery run is a short, low-intensity run, usually scheduled after a hard workout or long run. It's a form of active recovery that keeps you moving while adding as little training stress as possible to a body that's still fatigued. Despite a common belief, it won't flush out yesterday's lactate or guarantee a faster recovery. Its value lies in keeping you moving at minimal cost.
Recovery Run vs. Easy Run
Both should feel comfortable, but they do different jobs in a training plan. Easy runs build aerobic mileage. Recovery runs keep your training load low when you're already tired, so they're usually shorter than your regular easy runs, with the intensity dialed back further if needed. There's no universal pace cutoff between the two, and a recovery run doesn't have to be slower than every easy run you do.
Should You Do a Recovery Run Today?
To decide, weigh how you feel today against what your training plan calls for:
  • A recovery run may be a good fit: You're only mildly fatigued, have no pain, walk and run normally, and can keep the effort easy. The run also suits your current running frequency and fits your existing plan.
  • You may not need one: If you run only two or three times a week with rest days in between, an extra session just to "help" recovery adds little.
When to Choose Rest, Walking, or Cross-Training
If those conditions don't apply, skip the recovery run and adjust based on how tired or uncomfortable you feel:
  • Switch to light activity: If you can't keep a run easy but still want to move, try a short walk or a familiar low-intensity activity like cycling or swimming. Keep it easy, and leave the planned workout volume behind.
  • Prioritize rest: Much less sleep than usual, overall exhaustion, or several workouts in a row feeling harder than normal are all good reasons to skip the run. Protect your sleep rather than cutting into it to fit in a session.
  • Stop running: Localized pain, pain that gets worse, or a change in your form to avoid discomfort are all signs to end the run. Persistent or recurring pain needs its own attention, so get a professional assessment if needed.
After an all-out half marathon or marathon, don’t follow the same recovery plan you’d use after a typical long run. If walking still feels awkward or you’re noticeably exhausted, it’s too soon to jump back into running.
If you’re unsure how you’re feeling, use recent sleep data, training load, and HRV trends to help guide your decision. If your HRV stays outside your normal range for several nights, consider it alongside how you feel. One night’s reading alone shouldn’t determine your training plan.
How to Do a Recovery Run
Once you've decided to go, keep it simple: pick a route, set a time limit, and start easy. Here's how to approach effort, duration, and route, followed by a step-by-step example.
Set Your Effort
Start at an effort where you can speak in full sentences without difficulty. RPE 2 to 3 out of 10 is a useful starting point. Your breathing should stay steady enough for natural conversation without any conscious control. Your legs may still feel a little tired, but the run shouldn't get progressively harder.
If you use heart rate, treat it as a way to check that your effort is still easy, not a reason to speed up to reach a particular zone. Different devices may define heart rate zones using maximum heart rate, heart rate reserve, or lactate threshold heart rate. Avoid applying percentages or zone boundaries from one method directly to another.
Adjust your pace to how you feel that day. Start slower than usual and use the first few minutes to check that your breathing and running form feel natural. There’s no need to hit a target pace or run slower than every one of your regular easy runs.
Set a Time Limit
Plan your recovery run by time rather than setting a distance you have to cover. 20–30 minutes can be a practical starting point, as suggested in some running training guides. This is a general guideline, not a target you need to hit. If your usual runs are shorter or you’re not feeling your best, go shorter. Set a time limit before heading out, with room to finish early, and count any walking toward your total time. Even if you feel good, there’s no need to extend the run or make up the distance from your original plan.
Choose an Easy Route
Choose a flat, familiar route with an easy way to turn back to limit the extra effort that hills and technical terrain can add. Slow down on climbs and walk when needed. There’s no reason to push harder just to keep running continuously.
Weather can affect how easy a run feels, too. In hot, humid, or windy conditions, the same pace may take more effort. Slow down, shorten the run, or head out during a cooler part of the day. An indoor treadmill is another option.
A Simple Recovery Run Example
Here’s how a 30-minute recovery run might look in practice. This example is for runners who already run regularly, feel only mildly fatigued, and have no pain. It’s a starting point, not a one-size-fits-all training prescription.
  • First 5 minutes: Start with a very easy jog and let your breathing and stride settle in. Don’t rush to hit a particular pace.
  • Middle 20 minutes: Settle into a steady, easy jog at the effort level described above. If you take short walking breaks, count that time toward the 20 minutes.
  • Final 5 minutes: Keep jogging easily or gradually transition to walking. There’s no need to pick up the pace at the end.
If the effort starts to feel noticeably harder at any point, you can finish early. There’s no need to complete the full 30 minutes. Afterward, record the actual duration and how the run felt overall, including whether you finished early or took walking breaks.
If you’d like your watch to guide you through each stage, you can create a structured workout in Suunto App, set the duration for each stage, and sync it to a compatible Suunto sports watch.
How to Tell If Your Recovery Run Is Too Hard
If the run starts to feel harder as you go, or leaves you noticeably more fatigued afterward, it’s worth reassessing the effort and duration. Here’s what to look for during and after the run, and how to adjust.
During the Run
These signs suggest your recovery run may be too hard:
  • You could hold a natural conversation at first, but now you can only manage short sentences and your breathing is noticeably heavier.
  • Holding the same pace takes more effort, your legs feel increasingly heavy, and your stride starts to feel forced.
  • Your pace stays about the same, but your heart rate keeps climbing and the effort feels noticeably harder.
If you notice these changes, slow down first. If your breathing and running form still don’t feel easy, switch to walking or end the run early. Even if your heart rate stays within your target zone, don’t ignore a clear increase in effort.
After the Run
If you feel noticeably more fatigued after the run than you did before heading out, the session may have been too long or too hard. New pain or worsening discomfort is another sign that your current approach needs to change.
Think back over the run and check whether you went longer than planned, struggled more in the second half, or pushed harder on hills. If you use Suunto, you can also review your duration, heart rate graph, and time in each zone in the app to help pinpoint where the effort changed.
Consider your recent training load, sleep, and fueling when looking for possible causes. Then decide whether to shorten the run, lower the intensity, or take a rest day. Don’t assume the recovery run itself is the only reason you feel fatigued.
Takeaways
A recovery run exists to keep extra training stress low. Make sure you're ready to run, set an easy effort and a duration you can cut short, adjust as you go, and record the actual workload afterward. Resting, walking, or finishing early can all be the right training decision.
FAQ
Are recovery runs necessary?
No. Recovery runs are optional. Whether one makes sense depends on your training plan, weekly mileage, and how you feel that day.
Why does running slower feel awkward?
Slow running often feels awkward when you try to keep your usual stride length or cadence. Let your form adjust naturally to the slower pace instead. If it still feels awkward, mix in walking breaks, and stop if you feel any pain.
Can a recovery run be just one mile?
Yes. There's no minimum distance for a recovery run. One mile can be enough for a short, easy outing, depending on your usual routine and how you feel that day.
Do recovery runs count toward weekly mileage?
Yes. Recovery runs count toward your weekly mileage, and their duration and intensity add to your overall training load.
