Suunto Traverse Alpha User Guide - 2.1
Handling guidelines
Handle the unit with care – do not knock or drop it.
Under normal circumstances the watch does not require servicing. After use, rinse it with fresh water, mild soap, and carefully clean the housing with a moist soft cloth or chamois.
Remember to register your Suunto Traverse Alpha at www.suunto.com/support to get personalized support.
Indice
