Suunto Traverse Alpha User Guide - 2.1
Set up
To start using your watch:
  1. Keep START pressed to wake up the device.
  2. Press START or LIGHT to scroll to the desired language and press NEXT to select.
select language
  1. Follow the startup wizard to complete initial settings. Set values with START or LIGHT and press NEXT to accept and go to the next step.
startup wizard Traverse
After completing the setup wizard, charge the watch with the supplied USB cable until the battery is fully charged.
connect USBcable
If a blinking battery symbol is displayed, Suunto Traverse Alpha needs to be charged before starting.
If the battery dies, and you recharge the product, press and hold START to start the product
Indice
