Suunto Vertical User Guide
Indice
Indice
- Touch screen and buttons
Suunto Vertical has a touch screen and three buttons you can use to navigate through displays and features.
Swipe and tap
- swipe up or down to move in displays and menus
- swipe right and left to move backwards and forwards in displays
- tap to select an item
Upper button
- press to move up in views and menus
- from watch face, long press to define and open shortcuts
Middle button
- press to select an item
- keep pressed to go back in settings menu
- from watch face, press to open the pinned widget
- from watch face, long press to open settings menu
Lower button
- press to move down in views and menus
While recording an exercise:
Upper button
- press to pause and resume the activity
- keep pressed to change activity
Middle button
- press to change displays
- long press to go back to the previous display
Lower button
- press to mark a lap
- long press to open the control panel where you find the exercise options
- when the activity is paused, press to end or discard the activity
