Suunto Ambit3 Peak User Guide - 2.5
Shortcuts
By default, when you keep View pressed in Time mode, you toggle the display between light and dark. This shortcut can be changed to a different menu item.
To define a shortcut:
  1. Keep Next pressed to enter the options menu or press Start Stop to enter the start menu.
  2. Browse to the menu item to which you want to create a shortcut.
  3. Keep View pressed to create the shortcut.
Shortcuts cannot be created to all possible menu items, such as individual logs.
In other modes, keeping View pressed accesses predefined shortcuts. For example, when the compass is active, you can access the compass settings by keeping View pressed.
Indice
