New features for Suunto 9
Weather*
Follow context-based weather insights and warnings during your outdoor activity. Keep alert with storm alarms, measure water temperature or notice if your hike is going past the sunset. Feature available under SuuntoPlus™.
*Available only for Suunto 9 Baro
Climb
Keep track of your effort while hiking up a mountain, rock climbing, doing hill repeats in your backyard or running up stairs. Feature available under SuuntoPlus™. Climbs can be viewed afterwards in the Suunto app.​
Loop
Automatic location-based lap insights help you analyze the stats for each loop. Excellent feature when running on a track or cross-country skiing the same loop. Feature available under SuuntoPlus™. Loops can be viewed afterwards in the Suunto app.
Safe
Quick access to your GPS coordinates and other key information of your current location as well as your starting point. Useful when sharing your location with a friend, when you need to radio for help or navigating back to your car. Feature available under SuuntoPlus™.
Bearing navigation
Navigate on the go. Choose your target direction, get the bearing and off you go! You can also define your target distance and altitude. Great orienteering tool for mountains and forests.
Sprint
Running pace / Cycling power
Track sprints automatically while running or cycling to see the number, distance, and time of each interval during your training session. Sprints are identified based on the changes of your running pace or cycling power. Feature available under SuuntoPlus™. Sprints can be viewed afterwards in the Suunto app.
New outdoor watch face
See key insights of your surroundings while getting ready for your adventures. The design is inspired by Suunto’s heritage with marine compasses.
Wings for Life World Run
Getting ready for the race? The Wings for Life World Run feature simulates the Catcher Car to motivate your daily workouts and help you train for the race. Feature available under SuuntoPlus™.
Popular starting points
When heading to a new place or route, it’s often hard to figure out where to start. Check out popular starting points in the Suunto app to easily know where to start your adventure from.
Popular routes
Getting bored of running the same trails but not sure where to go? We made finding new routes easy for you by adding popular routes to the Suunto app. These routes are generated from the exercises of the Suunto community.
My tracks
See your own personal heatmap with a daily, monthly, and current year view. You can also compare your tracks with the most popular routes for your sport.
New Suunto app homescreen
Improved Suunto app home page will give you direct access to your calendar, activity totals and map.
New outdoor partners
Find your next trip from Sportihome, check the best routes with Wikiloc or view your tracks with Land. Suunto partners give you tools for your next trail run or mountain trip. Learn more from suunto.com/partners.
Adventure starts here.
Suunto equips you for your outdoor adventures – discover new trails, stay confident in the wilderness and train for longer explorations.
Update the software of Suunto 9 to version 2.13.18 to receive these new features and functionalities.
Learn more
비디오
Learn more about using our digital services as a Suunto Spartan or Suunto 9 user.
How do I use maps and routes with the Suunto app?
SuuntoPlus™ - a solution that brings new features to your Suunto watch and enhances your experience.
장시간 트레이닝하는 동안 배터리 모드를 사용하고 배터리 수명을 연장시키는 방법에 대해 알아보세요.
본 비디오에서는 설정 메뉴에서 개인 페이스와 파워 영역을 설정하는 방법을 단계별로 보여줍니다.
이 동영상은 다음과 같이 단계별로 보여줍니다.
운동에 맞는 파워 목표를 활성화하는 방법.
운동하는 동안 목표 내에서 실시간 안내를 사용하는 방법.
운동에 적합한 페이스 목표를 활성화하는 방법.
SuuntoLink를 사용하여 시계에 최신 소프트웨어를 설치하는 방법에 대해 알아보세요. SuuntoLink 다운로드
Suunto 시계를 Suunto 앱 (iOS용)과 페어링하는 방법과 앱으로 시작하는 방법에 대해 알아보세요.
Suunto 시계를 Suunto 앱 (Android용)과 페어링하는 방법과 앱으로 시작하는 방법에 대해 알아보세요.
미지근한 물과 순한 비누로 시계를 정기적으로 청소하십시오.
*실제 배터리 수명은 사용량과 조건에 따라 다를 수 있습니다. 울트라 배터리 모드를 사용할 경우, 배터리 수명은 증가되지만 손목 심박수 추적 기능은 정지됩니다.  엔듀어런스 배터리 모드에서, 배터리 수명은 손목 심박수의 경우 40시간이고 HR 벨트로는 50시간입니다. 운동 중에는 터치를 사용할 수 없지만 사용자 정의 모드에서 작동시킬 수 있습니다.
데이터 모니터링의 정확도손목 기반 심박수의 정확도를 참조하세요.
자세히 알아보세요
Suunto 9에 대한 지원
Suunto 시계에 대한 사용 방법 비디오, FAQ, 튜토리얼 기사 및 세부적인 지원 정보를 찾아보세요.
제품 지원
