Suunto Race User Guide
- Automatic display brightness
The display has three features that you can adjust: the level of brightness (Brightness), whether the inactive display shows any information (Always-on display), and whether the display activates when you raise and turn your wrist (Raise to wake).
The display features can be adjusted from the settings under General > Display.
- The Brightness setting determines the overall intensity of display brightness; Low, Medium or High.
- The Always-on display setting determines if the inactive display is blank or shows information, for example, the time. Always-on display can be toggled to on or off: - On: The display shows certain information all the time.
- Off: When the display is inactive, the screen is blank.
- The Raise to wake feature activates the display when raising your wrist to look at the watch. The three options for Raise to wake are: - Off: Raising your wrist does nothing.
- Display only: Raising your wrist only activates the display. A button press is required to use the watch.
- Full wake mode: Raising your wrist activates the watch, making it ready to use.
Prolonged use of the high brightness display reduces battery life and may cause screen burn-in. Avoid using high brightness for extended period to lengthen display lifetime.
