Zone 2 Training for Runners: How to Find Your Zone 2
SuuntoRun — 17 shtator 2026
For endurance sports such as marathon and trail running, getting faster isn't simply about training harder. Long-duration performance depends on your body's ability to sustain energy production, handle training volume, and maintain a steady output over time. Through low-intensity, sustained aerobic work, Zone 2 training helps build this foundation. This article explains how to find your Zone 2, understand the principles behind it, and incorporate it effectively into your training plan.
At a glance
  • Zone 2 is a low-intensity aerobic training zone.
  • Its primary value lies in building a strong aerobic foundation.
  • There is no single method for finding your individual Zone 2.
  • Zone 2 should be part of a complete training plan, not the entire plan.
  • The benefits of Zone 2 are primarily seen through long-term changes.
  • Consistency matters more than short-term intensity.
What Is Zone 2?
Zone 2 is a training intensity zone defined by heart rate. In the commonly used five-zone heart rate model, training intensity is divided into different zones based on an individual's heart rate data, with Zone 2 representing a low-intensity aerobic zone. Different training systems may use data such as maximum heart rate (HR max) or lactate threshold to determine these zones.
What Should Zone 2 Feel Like?
In practice, heart rate isn't the only way to gauge intensity. Your perceived effort can also help you identify whether you're in Zone 2:
  • Comfortable conversation without catching your breath
  • Heavier breathing, but still manageable
  • Finishing the workout with plenty left in the tank
Why Does Zone 2 Feel So Slow at First?
When many runners first start Zone 2 training, their pace drops noticeably, and they may even need to use a run-walk approach.
  • Early in training, aerobic efficiency and the ability to use fat for fuel are not yet fully developed. At higher paces, the body relies more heavily on glycogen, causing heart rate to rise quickly.
  • With consistent training, you'll gradually notice improvements such as running faster at the same heart rate and experiencing less fatigue after long runs.
Why Zone 2 Training Matters for Running
The value of Zone 2 training lies in the adaptations it supports across several key aspects of endurance performance, including improving aerobic capacity, increasing sustainable training volume, and supporting higher-intensity training.
man running with suunto watch in forest
Build a Strong Aerobic Foundation
The primary role of Zone 2 training is to gradually improve the body's ability to produce energy aerobically over time.
During low-intensity, sustained exercise, the body continuously relies on oxygen to produce energy. With consistent training, the muscles gradually adapt, including an increased capacity for fat oxidation, allowing the body to use fat more effectively as a fuel source during prolonged exercise.
In simple terms, the body becomes more efficient at sustaining the same level of exercise.
Increase Training Volume with Less Fatigue
Endurance gains depend not only on the stimulus from individual workouts, but also on how much effective training you can consistently complete over time.
Compared with high-intensity training, Zone 2 places less stress on the muscles and metabolic systems, which generally means a shorter recovery time. This allows runners to gradually increase training frequency and volume without continually accumulating excessive fatigue.
Over time, greater training consistency means more opportunities for the body to adapt, leading to continued training improvements.
How to Find Your Zone 2 Heart Rate
Zone 2 is not a fixed heart rate number. It can vary depending on factors such as maximum heart rate, lactate threshold, aerobic fitness, and training level. Runners can therefore use different methods to find the Zone 2 range that works best for them.
1, Traditional Calculation
Traditional calculation is one of the most common starting points and typically estimates Zone 2 based on maximum heart rate. Zone 2 is generally around 60–70% of maximum heart rate, but because maximum heart rate varies between individuals, age-based formulas are best used as an initial reference.
2. Lactate Testing
One of the more accurate ways to determine Zone 2 is to identify your lactate threshold (LT). Lactate threshold represents the point at which the body transitions from a relatively stable aerobic state to a state where blood lactate begins to accumulate more rapidly.
The most direct approach is laboratory lactate testing, which measures changes in blood lactate during an incremental exercise test and uses the resulting lactate curve to determine LT.
For recreational runners, lactate threshold can also be estimated using indirect tests such as the 30-minute Time Trial, VDOT, and Conconi Test. These methods do not directly measure lactate, but instead indirectly estimate LT using factors such as heart rate, pace, or performance.
Once LT is established, you can determine the corresponding lactate threshold heart rate (LTHR). Depending on the training zone model being used, LTHR can then serve as a reference for defining heart rate zones and determining your Zone 2 range.
checking metrics in Suunto during running
3. Heart Rate Drift Test
The Heart Rate Drift Test is more practical for everyday training. During a sustained low-intensity run, keep your pace relatively steady and observe how your heart rate changes in the second half. If heart rate remains relatively stable, the intensity is generally within a suitable aerobic range. This method requires no laboratory testing, but can be affected by factors such as weather, fatigue, and hydration.
4. Talk Test and Perceived Effort
The Talk Test is one of the simplest ways to gauge intensity based on perceived effort. Zone 2 generally feels like an intensity where you can speak in full sentences and carry on a simple, natural conversation.
5. Using Suunto Products
Suunto products can make heart rate training easier to apply in practice. Suunto can automatically set default heart rate zones based on maximum heart rate, while on Suunto Run, runners can choose between maximum heart rate, heart rate reserve, and lactate threshold heart rate zone models. You can also customize your heart rate zones to better match your training needs, while Suunto App lets you track long-term changes in heart rate, training load, and recovery to better understand your Zone 2 progress.
Suunto watch face
How to Use Zone 2 Training in Your Running Plan
After learning about Zone 2, many runners may wonder:
“Should all my training be Zone 2 from now on?”
The answer is no. Zone 2 is the foundation of endurance training, but it is not the whole picture.
1. The 80/20 Training Principle
Many endurance athletes follow a roughly 80/20 approach, with around 80% of training performed at low intensity (Zone 1–2) and 20% at higher intensities. This structure allows runners to build their aerobic base while maintaining enough high-intensity stimulus to develop speed and race performance.
2. Balance Weekly Training Volume
In your training plan, gradually building endurance often means increasing training frequency rather than simply making individual workouts harder. A Rest/ Deload Week every 3–4 weeks can also help reduce accumulated fatigue by temporarily lowering training volume.
By balancing training volume with adequate recovery, you can better manage your weekly workload and avoid increasing your training load too quickly.
3. Adjust Zone 2 Intensity Based on Conditions
Zone 2 training does not mean maintaining the same pace in every session.
Heat, humidity, poor sleep, fatigue, dehydration, and low energy availability can all cause heart rate to rise. Rather than pushing harder to maintain your usual pace, adjust your intensity based on how you feel that day. During longer sessions, make sure to replenish fluids, carbohydrates, and electrolytes to maintain training quality.
Suunto watch face
4. Use Run-Walk Strategies When Needed
For trail runners, keeping the intensity in Zone 2 is generally more challenging than road running. In environments like steep climbs, high altitude, and technical terrain, heart rate can quickly rise.
In these situations, slow down or even switch to brisk walking to keep your heart rate within the target zone. As long as the intensity is appropriate, walking can still provide an effective Zone 2 workout.
How to Know Your Zone 2 Training Is Working
The benefits of Zone 2 training usually do not appear as quickly as the effects of a single high-intensity workout. Instead, they are reflected in gradual improvements in efficiency over time.
Runners can look for several signs that their Zone 2 training is working:
Heart Rate and Pace Improvements
One of the clearest signs of progress is running faster at the same heart rate, or maintaining the same pace at a lower heart rate.
These changes indicate that your body is becoming more efficient at handling the same exercise load and that your aerobic efficiency is improving.
Better Recovery and Training Consistency
The value of Zone 2 is not only reflected in individual runs, but also in your ability to handle training load over time. As your aerobic base improves, you may find that you recover faster after long runs and feel less fatigued the following day.
For Suunto users, training load, recovery status, and long-term heart rate trends can help you track how your body is adapting to training.
Learn more about Recovery here.
When Will You See Results?
The benefits of Zone 2 training take time to build rather than appearing overnight. Some runners may notice that running feels easier and their heart rate is more stable within a few weeks, while 2–3 months of consistent training may bring more noticeable changes in pace and long-distance endurance. More significant improvements in endurance typically take several months or longer, making Zone 2 a long-term training approach.
TAKEAWAY
The value of Zone 2 lies not in deliberately slowing down, but in using consistent training over time to build a stronger aerobic system and greater training capacity. For marathon and trail runners, consistent accumulation matters more than pushing to the limit every time, helping create a stronger foundation for running faster, farther, and more consistently.
Next time you run, pay a little less attention to your pace and a little more attention to whether your body is becoming more efficient and more resilient.
FAQ
Can You Still Get Benefits from Zone 2 Training If You Have to Walk?
Yes.
For beginners, trail runners, and those training at high altitude, a run-walk approach can be an effective way to stay in Zone 2.
The goal is to stimulate the aerobic system, not to maintain continuous running.
As long as your heart rate and exercise intensity remain within the target range, brisk walking can still provide an effective Zone 2 workout.
Are Zone 2 Heart Rate Zones the Same for Running and Cycling?
Not necessarily.
Cycling uses different muscle groups, involves less weight-bearing, and has different movement demands than running. For many people, maximum heart rate is also lower when cycling than when running.
For this reason, it is best to determine your Zone 2 separately for running and cycling.
Can Zone 2 Training Alone Help You Run a Faster Marathon?
It can improve your aerobic foundation, but it is not a complete training plan.
Zone 2 can help build endurance, increase training volume, and support recovery. However, marathon performance also requires other types of training, including:
  • Marathon-pace training
  • Threshold training
  • Fueling strategy practice
The best results come from combining different types of training rather than relying on Zone 2 alone.
