Heart Rate Recovery: What's a Good HRR & How to Improve It
SuuntoRun — 12 أيلول 2026
When you run, pace, distance, and heart rate are usually the numbers that get the most attention. What happens to your heart rate after you stop, however, can be just as informative. Heart rate recovery (HRR) measures how quickly your heart rate drops after exercise and can offer useful insight into how your body is responding to training and recovery.
Understanding how HRR is calculated, what can affect it, and how to interpret the number can help you make better use of your heart rate data over time.
What Is Heart Rate Recovery?
Heart rate recovery (HRR) refers to how much your heart rate drops during the first few minutes after exercise. Finishing a run does not mean your body returns to rest immediately. Even after you stop, your heart rate takes time to come down from its elevated exercise level as your body gradually shifts back toward a resting state.
This drop is what your recovery heart rate reading helps capture. In sports and clinical research, 1-minute heart rate recovery is one of the most commonly used measures. It looks at how much your heart rate falls during the first minute after exercise. Some studies and fitness assessments also use 2-minute HRR or longer recovery periods.
Why Does Heart Rate Recovery Matter?
During exercise, your body shifts into a higher-output state: your heart beats faster, your breathing becomes deeper, and more blood is directed to the muscles that are working. Much of this response is driven by the sympathetic nervous system. Once exercise ends, your body begins shifting into recovery mode, with the parasympathetic nervous system gradually taking over and helping your heart rate and other functions settle back down.
A faster drop in your post-exercise heart rate generally suggests that your body is making this transition into recovery more efficiently. If your heart rate stays elevated for longer after exercise, it may indicate a slower recovery response. Clinical research has also linked slower heart rate recovery with a higher risk of all-cause mortality and potential cardiovascular health concerns.
This is why HRR can be useful not only for understanding exercise recovery and training response, but also as one piece of information about cardiovascular health. That said, a single HRR reading from a run or sports watch cannot diagnose a medical condition and should not be interpreted without considering factors such as exercise intensity, recovery method, medications, and symptoms.
hiking with suunto watch
What Is a Good Heart Rate Recovery?
There is no single value that defines a good heart rate recovery for everyone. HRR can vary with age, fitness level, and training status. The ranges below provide a general reference for 1-minute HRR by age, followed by a simple way to calculate your own result.
1. Heart Rate Recovery by Age
HRR tends to decrease gradually with age, so age-group data can provide useful context when interpreting your result. The heart rate recovery chart below is based on age-group data from a large population study and should be used only as a general reference. It is not intended for health screening, medical diagnosis, or as a Suunto product rating standard.
Age Group 1-Minute HRR Reference Range
30–39 About 13–29 bpm
40–49 About 13–28 bpm
50–59 About 11–27 bpm
60–69 About 9–24 bpm
70–79 About 6–20 bpm
These ranges are most useful for understanding general population patterns. For your own training, your personal HRR trend over time is usually more meaningful than where a single reading falls within the chart.
2. How Is Heart Rate Recovery Calculated?
To calculate your 1-minute HRR, you only need two heart rate readings:
Heart rate at the end of exercise − heart rate 1 minute later = 1-minute HRR
For example, if your heart rate is 180 bpm at the end of a hard run and drops to 152 bpm after one minute:
180 − 152 = 28 bpm
Your 1-minute heart rate recovery is 28 bpm.
check recovery heart rate and other metrics in suunto app
If you track HRR regularly, try to measure it under similar conditions each time. Start the recovery period at the same point after exercise and use the same device and measurement method whenever possible. This makes your results easier to compare from one workout to another.
What Affects Heart Rate Recovery?
Heart rate recovery can be influenced by your training status, environment, and how the measurement is taken. Some of the main factors include:
  • Exercise type and intensity: Running, cycling, easy workouts, and high-intensity sessions can all produce different heart rate responses. For more meaningful comparisons, it is best to compare HRR from similar types and intensities of exercise.
  • Training fatigue and recovery: Heavy training loads, insufficient recovery, or accumulated fatigue can temporarily affect how quickly your heart rate comes down after exercise.
  • Heat and hydration: Hot or humid conditions, as well as dehydration, can place extra strain on the cardiovascular system and keep your heart rate elevated for longer after a workout.
  • Sleep, stress, and caffeine: Poor sleep, mental stress, and caffeine before exercise can all influence the autonomic nervous system and affect your post-exercise heart rate response.
  • Cool-down method: Walking or jogging after a workout can produce a different HRR reading than stopping and sitting still right away. If you track HRR over time, try to keep your recovery method consistent.
  • Device and signal quality: Wrist-based optical heart rate readings can be affected by watch fit, movement, skin temperature, and sweat, which may cause fluctuations in readings at the end of exercise and during recovery.
For this reason, HRR is best viewed as a trend that should be interpreted in the context of your training, rather than a single number that defines your recovery or fitness.
How to Improve Heart Rate Recovery?
Improving HRR is less about training the number itself and more about building better cardiovascular fitness and supporting your recovery and overall health over time. What some devices or platforms call a cardio recovery rate is still shaped by your broader fitness and recovery status rather than by one specific type of HRR training.
cycling outside with suunto watch
A few habits can help:
  • Build a consistent aerobic base: Easy runs, long runs, and other steady aerobic sessions can gradually improve cardiovascular fitness.
  • Add some higher-intensity work: Tempo runs and interval sessions can provide a stronger cardiovascular stimulus when used appropriately.
  • Prioritize recovery: Balance harder workouts with rest days and easier sessions to avoid letting fatigue build up.
  • Get enough sleep: Consistent, high-quality sleep supports recovery from training and helps your body adapt to exercise.
  • Stay hydrated: Replacing fluids before and after exercise can help reduce the effects of dehydration on post-workout recovery.
  • Increase training load gradually: Avoid sudden jumps in volume or intensity, and give your body enough time to adapt.
Learn more about Recovery here.
1. Common Misconceptions About Heart Rate Recovery
There are a few common misunderstandings when using HRR to assess recovery:
  • A low HRR reading means something is wrong: HRR can be affected by the day’s workout, fatigue, environmental conditions, and how it is measured. A single lower reading does not necessarily mean your fitness or recovery has changed.
  • Higher HRR is always better: A faster drop in heart rate generally reflects a quicker recovery response, but HRR is not a number you need to keep pushing higher.
  • HRR from different workouts or devices can be compared directly: Different sports, training intensities, measurement windows, and device calculations can all produce different HRR values, so the numbers are not always directly comparable.
  • You can train HRR directly: HRR is better understood as a reflection of your overall cardiovascular fitness and recovery status. Consistent training, proper recovery, and healthy habits can improve your overall fitness and may help your HRR improve over time.
2. When Should You Pay Closer Attention?
A single low HRR reading, or one that looks different from your usual pattern, is not usually enough to suggest a problem. What matters more is a consistent drop from your usual HRR under similar exercise and recovery conditions, or an ongoing pattern of unusual changes.
If slower or unusual heart rate recovery is accompanied by symptoms such as chest pain, significant shortness of breath, dizziness, fainting, palpitations, or a sudden decline in exercise tolerance, do not rely on sports watch data alone. Seek medical advice.
If you take medications that affect heart rate, such as certain beta blockers, HRR should be interpreted by a healthcare professional in the context of your medication use and medical history rather than compared directly with values from people who are not taking those medications.
Track Your Heart Rate Recovery With Suunto
Selected Suunto watches, including the Race series, Vertical 2, and Run, support heart rate recovery tracking. These watches record how your heart rate drops during the recovery period after exercise, and you can review your HRR data in the Suunto App.
For long-term tracking, try to compare HRR under similar exercise and recovery conditions. It can also be useful to look at HRR alongside how fatigued you feel, heart rate variability (HRV), sleep, and your recent training load for a fuller picture of your recovery.
check recovery state by using suunto watch
Takeaways
Heart rate recovery can help you understand how your heart rate responds after exercise and provide useful context for tracking cardiovascular fitness and training recovery over time. A single HRR reading only tells part of the story, so consistent measurements under similar conditions are more useful for spotting meaningful trends.
With Suunto, you can track HRR alongside your other training and recovery data, giving you more context when planning what comes next.
FAQ
What Is a Good Heart Rate Recovery Rate for 2 Minutes?
There is no single “ideal” 2-minute HRR value that applies to everyone. Clinical research can provide some context. For example, one study found that a heart rate drop of less than 22 bpm after two minutes was associated with a higher long-term risk of all-cause mortality.
However, this value should be viewed as a research reference rather than a universal cutoff for every athlete or exerciser.
Is a Higher Heart Rate Recovery Better?
In general, under similar exercise and recovery conditions, a higher HRR means your heart rate has dropped more quickly after exercise. But that does not mean you should always aim for the highest possible number.
HRR after an easy run may look very different from HRR after a hard interval session. It is more useful as a measure of how quickly your body is recovering than as a score you need to maximize.
Why Is My Heart Rate Recovery Different on Different Devices?
Different devices may use different recovery periods and calculation methods. Some measure the change in heart rate after one minute, while others use a two-minute recovery period, so their HRR values may naturally differ.
Before comparing HRR across devices, check which type of HRR they measure and how the value is calculated.
Is Heart Rate Recovery the Same as HRV?
No. HRR measures how quickly your heart rate drops after exercise, while HRV measures the variation in time between consecutive heartbeats.
Both are related to the autonomic nervous system and recovery, but they provide different information. HRR focuses more on your recovery response after exercise, while HRV is commonly used to monitor day-to-day recovery and physiological stress.
