FREE SHIPPING FROM €150 | SIGN UP FOR NEWSLETTER | NEW LOWER PRICES
Using heart rate belt
A heart rate belt can be used during exercise. When you use a heart rate belt, Suunto Ambit2 S gives you more information about your activities.
Using a heart rate belt enables the following additional information during exercise:
  • heart rate in real time
  • average heart rate in real time
  • heart rate in graph form
  • calories burned during exercise
  • guidance to exercise within defined heart rate limits
  • Peak Training Effect
Using a heart rate belt enables the following additional information after exercise:
  • peak heart rate
  • recovery time
Troubleshooting: No heart rate signal
If you lose the heart rate signal, try the following:
  • Check that you are wearing the heart rate belt correctly (see Putting on heart rate belt).
  • Check that the electrode areas of the heart rate belt are moist.
  • Replace the battery of the heart rate belt, if problems persist.
  • Re-pair your heart rate belt with the device (see Pairing POD/heart rate belt).
  • Machine-wash the textile strap of the heart rate belt regularly.
