Suunto Spark User Guide
Dual device connection
You can connect your Suunto Spark headphones to two Bluetooth devices at the same time. With the help of the dual device connection function, you can easily switch to your phone and answer a call while listening to music from your computer.
When the headphones are already paired with a device with Suunto app:
- Enable dual device connection in Suunto app.
- Put the earbuds in the charging case.
- Press the button on the charging case for 5 seconds to enter pairing mode.
- Under the Bluetooth settings of the second compatible device, open the list of nearby devices.
- Find Suunto Spark on the list and pair it with the second device.
- When you connect the second device, the first device temporarily disconnects from the headphones. To reconnect the first device, go to the Bluetooth settings of the device or simply restart the headphones.
You can check the list of the connected devices in Suunto app.
When you use Suunto Spark with two paired devices at the same time, the headphones determine their own priority based on the order of the played content and the tasks. Normally, the first played audio takes precedence over the second, and phone calls take precedence over audio playback. However, the actual operation of different brands and models of the compatible devices may vary.
