Polarized Training: How to Set Zones and Plan Your Week
SuuntoRun — 5 oktoober 2026
If your recovery is dragging and your performance has stalled, the fix may lie in how you distribute training intensity rather than how hard you work. Too much time in the middle can leave you working too hard to recover well, but not hard enough to get a strong training stimulus.
Polarized training helps shift that balance. Most of your training stays easy, while a smaller amount is reserved for high-intensity work. This article explains how polarized training works, how to set your intensity zones, how to structure your training week, and how to adjust based on your data and how you feel.
Polarized Training Explained: How It Compares to 80/20 and Pyramidal Training
Polarized training is a way of distributing training intensity across three broad levels: most training is done at low intensity, a smaller amount at high intensity, and relatively little at moderate intensity. These three intensity levels are typically defined using the first lactate threshold (LT1) and second lactate threshold (LT2).
Polarized training is often associated with 80/20 training. The 80/20 approach generally means spending around 80% of your training at low intensity and the remaining 20% on quality work, which can include moderate-intensity, threshold, or high-intensity training. Strictly speaking, polarized training places more emphasis on keeping moderate-intensity work to a minimum. The two approaches are closely related, but they aren’t exactly the same.
Looking at the relative share of low-, moderate-, and high-intensity training, polarized training differs from two other common approaches to endurance training:
Training Model Intensity Distribution
Polarized training Most training is low intensity, followed by high intensity, with the least at moderate intensity
Pyramidal training Most training is low intensity, followed by moderate intensity, with the least at high intensity
Threshold training Places more emphasis on training around threshold, with a larger share of moderate-intensity work
Training intensity comparison among polarized, pyramidal and threshold-focused
The difference between these models isn’t just how much time you spend at each intensity. It’s also about how you distribute training stress. Polarized training keeps most sessions at low intensity to help manage fatigue and maintain consistency, while a smaller amount of high-intensity work provides a clear training stimulus.
Does Polarized Training Really Work?
Polarized training is not a set formula that guarantees better results. Research suggests that, among some trained runners and endurance athletes, a polarized intensity distribution may improve endurance performance, short-distance performance or running economy. However, the available research is limited by sample sizes and training conditions. Training volume, fitness level, recovery capacity, and the timing of the training cycle can all affect the outcome, so the same results should not be expected for every runner.
From a training-management perspective, the value of polarized training is less about hitting an exact percentage every week and more about being intentional with how you distribute your effort. Most training stays at low intensity, moderate-intensity work is kept in check, and a smaller amount of high-intensity work provides a clear stimulus. For newer runners, building a consistent training routine and finding a training load they can recover from is usually more important than following a strict polarized ratio. For runners with an established training base, polarized training can be used as a framework for managing training stress.
How to Find Your Polarized Training Zones?
Finding your polarized training zones starts with identifying the two key boundaries: LT1 and LT2. These thresholds can then be used to define your intensity zones. In day-to-day training, use heart rate, pace, breathing, and perceived effort together to check whether you’re training at the right intensity.
Find Your Lactate Threshold 1 & 2
Blood lactate or respiratory gas testing can directly identify LT1 and LT2, along with the heart rate and pace associated with each threshold. This is one of the most direct ways to set your personal training zones. If you don’t have access to laboratory testing, your training data and structured field tests can still give you useful reference points:
  • LT1: The aerobic threshold can be a practical reference for LT1. Choose a flat, familiar route and run at an easy, steady effort. You should be able to hold a natural conversation and keep your breathing relaxed. If your heart rate continues to rise noticeably during the second half of the run, your effort may already be approaching or exceeding the upper end of your low-intensity range. Consistent heart rate and pace across multiple runs can help you establish an initial estimate of LT1.
  • LT2: Runners with an established training base can use a structured field test or a threshold estimate from their device as a reference. The duration, intensity, and calculation method should follow the specific testing protocol being used.
check heart rate in suunto watch
These methods can give you a starting point for setting your training zones, but they don’t replace laboratory testing. It’s best to cross-check your estimates against data from multiple workouts and how you feel during training.
Set Your Three Polarized Training Zones
Once you’ve identified LT1 and LT2, you can use these two thresholds to divide your training into three intensity zones:
Three-Zone Model Physiological Boundary Role in Polarized Training
Zone 1: Low Intensity Below LT1 Builds aerobic training volume
Zone 2: Moderate Intensity Between LT1 and LT2 Kept relatively low in polarized training
Zone 3: High Intensity Above LT2 Provides high-intensity stimulus
For example, if your LT1 heart rate is around 145 bpm and your LT2 is around 170 bpm, you could initially treat anything below 145 bpm as low intensity, 145 to 170 bpm as moderate intensity, and anything above 170 bpm as high intensity.
Note that Zone 2 in this three-zone model is the moderate zone between LT1 and LT2, which differs from the easy “Zone 2” used in five-zone heart rate models
Use Pace, Breathing and Effort to Check Your Intensity
Heart rate is useful for tracking training zones, but when you’re actually running, it also helps to check your pace, ability to talk, and perceived effort.
  • Zone 1: Pace is below the pace associated with LT1. Your breathing stays relaxed, you can speak in full sentences naturally, and the effort feels sustainable for a long time.
  • Zone 2: Pace falls between the paces associated with LT1 and LT2. Your breathing becomes deeper, and holding a full conversation starts to feel difficult, but you can still maintain a steady rhythm.
  • Zone 3: Pace is above the pace associated with LT2. Your breathing is noticeably harder, and you can usually only speak a few words or short phrases. This zone is often trained through intervals.
Keep in mind that heart rate can lag behind your effort during interval workouts. Use your target pace, perceived effort, and the quality of each interval to help control the intensity.
With a Suunto sports watch, you can adjust your personal heart rate zones based on your threshold heart rate and review the time spent in each zone after a workout. This can help you see whether your actual training intensity matches your plan. If wrist-based heart rate is affected by factors such as arm movement, a heart rate belt can provide more consistent data.
road running with suunto heart rate belt
How to Structure a Polarized Training Week?
Once you’ve set your personal training zones, start planning your week around them. Keep your total running volume at a level you can manage consistently, then add high-intensity sessions, a long run, and recovery days. Finally, check your overall intensity distribution to make sure it matches your plan.
Arranging Training and Recovery Across the Week
When planning your week, use the number of sessions to control how often you do high-intensity work, then check the time spent in each zone to see how your actual intensity is distributed. For interval workouts, count the warm-up, work intervals, recovery periods, and cool-down based on their actual intensity. Time spent in each zone usually won’t match the percentage of workouts, and there’s no need to force the numbers to hit a specific ratio. A typical week can be structured around these steps:
  1. Set a sustainable number of runs and total volume. Start with the running frequency and weekly training time you’ve already adapted to. Then factor in work, rest, and other activities to determine how much training time you can realistically use that week.
  2. Choose the key workouts for the week. Based on your training background and goals, decide whether to include a high-intensity interval session and whether to include one longer run.
  3. Schedule the biggest training loads and recovery around them. If your week includes both high-intensity intervals and a longer run, try to separate them and place rest or low-intensity runs before and after these sessions. Strength training and other demanding activities should also be considered as part of your overall training load.
  4. Fill the remaining time with low-intensity running. Keep most other runs below LT1, with the frequency and duration staying within what you can currently recover from.
For example, if you can consistently run five times a week, you could use one session for high-intensity intervals and keep the other four primarily at low intensity, with one of those runs being longer. If you can only run three or four times a week, you can reduce the number of low-intensity runs and decide whether to keep the high-intensity session based on how well you’re recovering. There’s no need to squeeze the same five-run workload into fewer days.
When using the Suunto app to plan interval workouts, you can follow the structured workout guide to set work and recovery phases and sync the workout to a compatible watch.
structured workout plan in suunto app
Adjusting Your Training Week
  • For Everyday Training: Your training schedule doesn’t have to look exactly the same every week. If you’re still carrying fatigue, shorten your low-intensity runs, push back your high-intensity session, or temporarily reduce your overall volume. If you occasionally miss a workout, there’s no need to make it up right away. Avoid stacking extra training onto the days around it and creating an unnecessarily heavy load.
  • For Race Preparation: When preparing for a half marathon or marathon, you can add a limited amount of threshold or race-pace work based on the demands of the event, while reducing some of your usual high-intensity intervals. Your weekly intensity distribution may become more pyramidal during this phase. Whether this approach makes sense depends on how well it matches your race demands and whether you can maintain a consistent balance between training and recovery.
How to Track Your Polarized Training Progress?
When reviewing your polarized training, look beyond performance and recovery. You also need to check whether your actual intensity distribution matches the plan: Is most of your training still low intensity? Can you maintain the quality of your high-intensity sessions?
Reviewing Your Intensity Distribution
Start by comparing the total time you’ve spent in each intensity zone over the past few weeks. If runs that were supposed to stay at low intensity regularly creep above LT1, you may be accumulating more moderate-intensity work than intended. If your high-intensity time has increased noticeably, look at where that extra intensity is coming from. Is it part of your planned training, or is it the result of running too fast, tackling more hills, or not recovering enough?
When making these comparisons, look at total training volume as well as the percentages. Even if the intensity distribution stays about the same, an increase in total running time can still mean more overall fatigue.
If you use a Suunto watch, you can use the Training Zone feature in the Suunto app to review your weekly intensity distribution and six-week average trends. You can also look at changes alongside chronic training load (CTL) and recovery-related data to get a broader picture of your recent training.
training zone dashboard in suunto app
Recognizing Progress and Making Adjustments
Progress with polarized training isn’t only about getting faster. Other signs include better control during low-intensity runs, consistent output during high-intensity workouts, and less lingering fatigue that affects the sessions that follow.
  • Low-intensity runs regularly drift into moderate intensity: Slow down, choose a flatter route if needed, or shorten the run so the effort stays within your target zone.
  • Repeatedly struggle to complete high-intensity workouts as planned: Check whether you’ve had enough recovery beforehand. You may need to reduce the amount of high-intensity work or leave more time between demanding sessions.
If your training is going smoothly, you can keep your current approach and track changes in performance under similar route and weather conditions over time. When you do need to adjust your plan, change the factor that appears to have the biggest impact first, then use your subsequent training data to see whether the adjustment is working.
Takeaways
The main lesson from polarized training is to put your limited energy where it matters most. A good training week isn’t just about how much you complete. It’s also about whether you can recover well enough to start the next week ready to train. When every workout has a clear purpose, it becomes easier to stay consistent and spot when something needs to change.
Think of intensity distribution as a tool to guide your decisions, not a fixed target you have to hit. The right balance can change as your schedule, training background, and race goals change. What matters most is finding an approach that lets you keep building fitness, recover between workouts, and gradually move toward your goals.
FAQ
Is Polarized Training the Same as 80/20 Training?
They’re closely related, but the emphasis differs. 80/20 training puts around 80% of your time at low intensity and 20% into quality work, which can include threshold sessions. Polarized training keeps moderate-intensity work to a minimum and puts most of that quality time into high-intensity efforts.
Does Polarized Training Work for Cycling and Swimming?
Yes, but the intensity zones and training sessions should be specific to each sport. Running heart rate zones shouldn’t be directly applied to cycling or swimming, and interval duration and recovery should be adjusted accordingly.
Does Cross-Training Count Toward the 80/20 Split?
Aerobic cross-training such as cycling and swimming can be included in your overall aerobic training distribution, as long as you use the same method for tracking all activities. Strength training isn’t included in the 80/20 split, but the fatigue it creates should still be factored into your recovery plan.
Can Easy Runs Include Strides?
Yes. You can add a few short strides to an easy run, gradually building speed and taking full recovery between each one. Because the fast efforts are brief, the overall run can still remain mostly low intensity. When tracking your intensity distribution, count the time spent in each zone based on the actual intensity of each effort.
